Tire size again
zikronix
I have a 2017 with stock 17" rims. I was trying to figure out what size tire i could goto with out rubbing. Currently have 255/70R17
https://www.gm-trucks.com/forums/topic/192873-biggest-tires-to-fit-on-stock-2014-sierra-sle-double-cab-with-25570r1/
https://www.gm-trucks.com/forums/topic/179256-biggest-17-rimtire-combo/
I run a different size wheel or I would provide more info for you. The first link seems to have what you need.  You could always go measure too.
If you don't want to read a little, you could go measure your truck yourself.  I run a different size wheel or I would provide more info for you. The first link seems to have what you need.
I searched and didnt see this thread. Ill check it out thanks!
If you're on a stock height 1500, I'd recommend a 275/70/17. There are even a few companies that make that size in a LT, load range C tire, which is perfect for a 1500, IMO. If you're leveled, then a 285/70/17 is a very popular size, but most of those will be load range E.
