DIC
18 minutes ago, Randy handy66 said:
Steering assist is reduced drive with care
Not trying to be a smart a$$ but are you asking what that means or is it a problem you’re now having? What year truck and what do you think made that occur? There is a wealth of knowledge on this site and you’re not the first to have this happen or inquire about it.
Oh Boy.
Another guess what's wrong with all the info.
Sorry, couldn't resist.
There is a recall for a software update due to electric power steering cutting out in low speed situations. I believe GM simply raises the cutoff voltage threshold so the electric power steering remains powered when voltage is low during low speed steering maneuvers.
https://www.motortrend.com/news/gm-power-steering-recall-affects-more-than-1-million-trucks-suvs/
Thank you...the OP never mentioned what year or anything about his/her vehicle so we’re all just guessing what the intent was ?
Myself included ;-)
The linked article states only 2015 year models.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
