Oil pressure low
I have a 2014 Chevy 1500 5.3 and the oil pressure is low according to my sensor. I have checked the oil and it’s good. What could this be?
Doesn't appear low to me if warmed up and idling as noted above.
Might want to buckle up.:rolleyes:
When you rev it up a little does the gauge raise? If so and doesn’t go silly on you, you’re good...if that was doing 70mph on the highway then I’d be concerned.
Yes it goes up when I rev up and when I’m cruising down the street the pressure is at about 35-40. Nothing sounds different to me when it’s running ether engine sounds good. Just not used to seeing it that low.
I've always been under the impression that the oil pumps in these motors is high volume low pressure. Meaning that it's moving a high amount of oil through it at a lower pressure.
I kind of freaked out back in 99 with my first 5.3 when it was hot at idle it had around 20 lbs. Between 35 and 40 at highway speed. It would be around 40-45 when cold.
Well after 225,000 miles it still ran fine and used very little oil.
Someone correct me if I'm wrong please.
Also the 0W-20 oil nowadays is like water thin so that would also contribute to the lower pressure IMO.
You’re good and like dieselfan1 said, the oil is very almost water thin...when fresh oil is in there it’s hard to even see on the dipstick, almost wish they’d make it light blue or something lol
So there is a service bulletin on this and you are fine. Even 10psi and the low idle warmed up 500rpm is OK.
To. Much pressure on the thinner oil would blow oil right through.
20psi at hot idle is perfectly normal. Our trucks have a 2 stage oil pump. Your oil preasure should spike up to 40-60 psi it you stab the throttle. If it doesnt come off of 20 psi under a load, then you have a problem.
Well the truck went down today, oil pressure dropped to 0 message on truck came up saying low oil pressure shut down truck. There is oil on the dip stick no leaks from top on the sides or below. Could it be oil pump gone bad? Engine made a real bad clunking sound.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 559 Guests (See full list)
