I just bought a 2016 with a warranty block. They performed the recall but the fix didn't remedy the situation. They are classing the actual changing of parts "warrenty" work and aren't willing to move forward and help. Looks like im gonna keep taking this further up as it's a huge safety issue. I see that someone got the recall done and parts replaced and it eased still an issue. Check this out.
https://www.carcomplaints.com/news/2018/gm-brake-vacuum-pump-failures-lawsuit.shtml
I had my pump replaced through an extended warranty plan in February when it went out.  I almost drove through my garage wall when the pump decided to shit the bed.
  • 3 months later...
I dropped my 2014 Silverado off this morning to have oil change and the software recall performed. I was just informed that they where unable to perform the recall as they don't have the part in stock.
So I asked the question that I understood that this was a "software upgrade" and that this shouldn't "require a part". The technician stated that initially that was the case but has now VERY recently changed and they will need to replace the vacuum pump and it is out of stock. This may not be the case for all years and models but IS the case for my 2014 Silverado 5.3L
So I just had the software update done for this on Wednesday. They never mentioned anything about a pump. Does this mean my truck will show up as having had it done and I'm SOL if this issue crops up? (never experienced that hard braking)
IDK. I just know that on my truck they have a vacuum pump on order.
I was involved in (2) accidents from this issue. After the second one I received a letter saying to bring my truck in for repair. Sure enough (I have paper work to prove) the dealer determined my booster was operating below the pressure threshold and was replaced at no cost by the dealer.
gm then played shady phone games with me lying to me saying ESIS, who “handles gm claims” was a 3rd party with no ties to gm only to later find out they work for gm. Either way they sent an inspector out who inspected every aspect of my truck for about 7 hours, they were trying to come back with proof that when I rear ended someone the brake was not being pressed. They can see if the air bag almost goes off. The inspection came back with nothing and Esis eventually offered me a laughable “settlement” which was “not an admission of guilt however an act of good faith by gm to repair my vehicle.”
Needless to say this has been going on for over a year, I’m not sure my truck is safe to drive and I do 110 miles a day. This whole thing has caused me severe stress and anxiety and I hope none of you have to deal with this. Luckily no one was seriously injured, but one party involved had a neck injury. Gm is a disgrace.
  • 10 months later...
No one else has had these problems??
Probably not enough for people to comment. Plus just just because booster fails it doesn't mean there are no brakes so people can still stop.
Sent from my SM-G975U1 using Tapatalk
  • 2 months later...
I just got my vacuum pump replaced today at the dealer. 2016 Silverado with 42k on it. I think they’ve seen enough of these they didn’t question me at all on it
  • 1 month later...
 Sorry just a bit dated on this thread, but like related.
  I have a 2017 Silverado, 71k miles, well cared for. My brakes have been acting up at low speeds, last 4+ weeks or so. I have a good code reader, shows ‘Electronic Brake Control Module’, code C0800-5A.
  This truck doesn’t currently have any recalls active. I have an appointment tomorrow afternoon, I don’t plan to throw the checkbook at the issue. I think it should of been taken care of.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
