Turning on reverse lights with cargo light switch
On 3/13/2019 at 7:06 PM, carnau said:
That's my biggest problem. lol Please don't think you're annoying me. I get forgetful and out of sight, out of mind you know. Again, I forgot this morning but I put a reminder on my phone to check tomorrow. Sorry about that.
Reminder
2 hours ago, FuturisticMC said:
Reminder
Have not forgot this time. Sent in a end view request for the connector so I could get it straight for you. =-)
On 3/16/2019 at 5:02 PM, FuturisticMC said:
Alright thanks a lot
Ok, So FINALLY getting some information that I need. Here is the schematic we need. I will look more into exactly how I would wire it after I get some time to sit down. lol
Actually... I like this one better after looking at it.
On 3/29/2019 at 4:16 PM, FuturisticMC said:
Reminder
Will look at it this evening, and get you a setup.
Ok, So here is how I would wire it.
1.) Lower the glove box and mount your relay to the air box.
1a.) Mount the switch to your dash knee bolster (or where ever you want it to go)
2.) Run 2 power wires (red) from the Battery to the inside of the vehicle using 14g red wire and  round insulated butt connectors at the battery side. Leave the wire loose at the battery and connect (1) red wire to terminal 87 of the relay using a blue insulated butt connector. Connect the other red wire to the On/Off toggle switch.
3.) Run a (red) wire from the other side of the toggle switch to terminal 86 of the relay
4.) Run a ground wire (black) from the inside passenger side dash mounting bolt using the black wire and an insulated round butt connector. Connect that wire to terminal 85 of the relay.
5.) Using the (Blue) wire, run a wire from terminal 30 of the relay, to the add a circuit. Install a 15amp blue fuse in the add a circuit and remove the cargo lamp fuse (F10) in the passenger fuse block. Install the add a circuit in the cargo lamp fuse (F10).
6.) Connect the red wires at the battery.
Always remember to use insulated crimping pliers when using insulated butt connectors. If not, it's pointless to have them.
Second, If you know how to solder, do away with the butt connectors because soldering is always better and just use heat shrink to cover your open wires.
Parts needed:
2 pin 25amp 2 way on/off switch. - https://amzn.to/2CYlnMC
Relay circuit -  https://amzn.to/2I7yJta
14 Gauge wire 100ft (4 colors) - https://amzn.to/2IaCTjV
Add a circuit - https://amzn.to/2K3HF5x
Insulated Heat Shrink Terminal kit (will have butt connectors and round terminals) - https://amzn.to/2FLwDfF
Stripping pliers -https://amzn.to/2TV8zfs
Insulated Crimping Pliers- https://amzn.to/2uLitWN
Non-LED Test Light - https://amzn.to/2Ibgq6m
Soldering
Lead/Rosin core Solder - https://amzn.to/2UfmYbj
Heat shrink kit - https://amzn.to/2FNgeaB
Parts needed:
Soldering
Is it possible to simplify these instructions or word them differently? For example there isnt a fuse block on the passenger side, is F10 the fuse number? Do you mean open or remove the glove box by "lower"?
There is a fuse block on the passenger side. I wired this up exactly on another truck just to see if it would work.
F10 is the fuse number like in the schematic above.
No, lower the glove box means to open it, then remove the 2 tabs that hold it up and it will lower down.
Will the fuse box be visible when I remove the glove box? This is on a 2013 silverado 1500
Wow. I thought you had bought a set of 2015 aftermarket mirrors to go on your 2015 truck. Y will refigure this for a 2013. lol I am sorry.
  • 4 weeks later...
These are the mirrors i have on a 2013 silverado 1500 LT. https://boostautoparts.com/collections/tow-mirrors/products/2007-5-2013-gm-tow-mirrors?variant=43621212039
I will restate my question also, I am trying to make my reverse lights come on with the cargo light switch, WHILE I am in other gears then park.
The reverse lights I am talking about are: The ones on the mirrors, the ones in the taillights, and the cargo lights will be on also.
Attached pictures show all of my reverse lights turned on, and the cargo light switch(the dimple lookin thing) which turns on the cargo lights when turned all the way to the right.
