GM-Trucks.com as a webradio show?
Zane
1 member has voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I just got off the phone with gentlemen from wsradio.ws
We discussed having a GM-Trucks.com & GM-Cars.com we radio show.  It would be once a month, about 2 hours long.
We would discuss vehicle reviews, new products, news, gm rep interviews, new gm product announcements..etc..
Of course, nothing is free, and it would cost us about 2k to start up with remote broadcasting equipment.  What do  you guys think?
Sounds like fun but also pricey :thumbs: .  Will you be able to somehow make a profit on your $$ and recoup some or all of your expenses over long term?  Excuse my ignorance but I don't really know a whole lot about how the business of webradio works.
You two know what you can handle time-wise more than anyone else. I'd rather see GM-TC get bigger and better first and I think I would concentrate more on GM-CC's development before anything else got started. Y'all have a couple of great websites here. Don't spread yourselves too thin and end up with three mediocre deals.
IMO, two grand is a lot of money that could be better spent elsewhere.  I vote no.  Maybe a few years done the road this could be a viable option, but I don't think the time is right.
    • Those are parts changers. It can get expensive though. I was a mechanic for 30 yrs. My truck has made this noise since new. I really don`t know what it is. It really doesn`t bother me. I`m still in warranty but have not brought it to the dealer.   I`m not buying the oil pump prime thing. Screw the TSB. I believe it`s in the trans pump gears. They rattle when that piss poor ULV oil drains off after a while. I believe those sharp tooth gears, with backlash, can rattle when dry. Not a vane style oil pump. Wonder who`s right? Me, or the TSB?🤔   Maybe I`m wrong?
    • Sounds about right. I miss the days of mechanics lol.
    • On the PCM side, blue PCM connector, pin 18, solid gray color (no stripe) wire circuit 435.  That is the EGR low circuit which an issue on that line (be it the wiring, the PCM or the EGR valve or system performance) will trigger P0401 when it tests that code.     There is also a VERY old TSB that states to make sure you clear the DTCs ANY time the PCM is unplugged, reprogrammed, or if the EGR valve is unplugged or replaced as the PCM has an auto zero function in the PCM for the EGR pintle data   61-65-59: SMU - SECTION 6E - ENGINE CONTROLS - CLEAR DTC'S - (Nov 25, 1996)   "CLEAR ANY DTCS FROM THE VCM ANYTIME AFTER DOING VCM REPLACEMENT/ PROGRAMMING, TURNING THE IGNITION ON WHILE THE EGR VALVE IS DISCONNECTED, OR REPLACING THE EGR VALVE."   Some diagnostic aid notes in the GM diag on P0401 for a 1995 S10 Blazer:   Diagnostic Aids Notice: In order to prevent further damage if the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged converter) using the procedure found on the restricted exhaust system check. If the exhaust system is restricted, repair the cause; one of which might be an injector which is open due to one of the following reasons: Stuck Grounded driver circuit Check the oil for possible fuel contamination if a stuck open fuel injector is found. Poor connection or damaged harness - Inspect VCM harness connectors for the following conditions: Backed out terminal BL 18 Improper mating Broken locks Improperly formed or damaged terminal Poor terminal to wire connection Damaged harness Intermittent test - If connections and harness check OK, monitor a digital voltmeter connected between terminal BL 18 and ground while moving related connectors and wiring harness. If the failure is induced, the voltage reading will change.
    • maybe get a service manual off ebay?  or check charm.li (website) or subscribe to alldata.com for it?
    • This biggest difference in a HM oil is in contains some  "Seal Conditioner". DEXOS oils and most shelf oils are "Dry" oils which over time harden seals. "Seal Conditioner" is more times than not, an Ester. Addition will soften the seals over time but will not repair one that leaks or has cracked. Esters also provide some cleaning but these HM oils don't contain enough to solve out hard deposits. Just the soft stuff.  Also a function of an Ester.    Ester's are not 'allowed' as a 'co-base" by license. Weird, right?  A certain amount is allowed as an additive. Bunch of game playing is what it is. It's why HM oils don't have a DEXOS approval.    DEXOS is a license 'with' a specification but is not a specification. Never was, never will be. It's GM's slot machine always paying the house. Use what you like.
