I'm screwed ( tailgate latch )
Kdiamond
Went out today and my tailgate latch is broke. Key was in locked position. I unlocked it and latch doesn't feel to be doing anything. Now lock won't turn at all. I have my trifold hard cover on and can't get to the back of the tailgate to work on the latch. I REALLY don't want to destroy my cover. It's way to expensive. Anyone else run into this? Forgot to add..... 2014 gmc 1500 with tailgate lock and back up camera.
Well that sucks. Can you call pop a lock and see if they can work on a tailgate? Maybe they can release the actually latching mechanism.
My only suggestion would be to drill and/or cut into the handle itself to be able to pull the rods that actuate the tailgate latch (I believe there's one coming from each side - 2 total). Not sure of exact locations on the handle of where to drill, but it's not thick and you could safely do it (slowly) without damaging any internal components. If your truck is a daily driver you'll obviously want to order a new tailgate handle ahead of time before jumping into this. OEM handles are all over eBay for $50-60. Good luck, I'd be in the same boat with my cover. No way to access the bed of the truck without seriously damaging the cover.
Sorry for the late response, can you post picture of what your handle looks like now? What you will try to attempt is to move the mechanism that the rods are attached too. The rods are stacked  with one on top of the other (not touching) and controlled by a lever that rotates clockwise when the left side the handle is pulled and pushes against it. So, if you could remove the just the handle (not the body), or pry it out to see the lever on the left hand side (facing tail gate), then push it up and too the left, should move rods to unlock (open) it.
Carparts.com has some good front and back photos of the handle. Looks like if you were to drill/cut, the lower left corner is the spot to do it (looking at it from the outside). Nothing is behind it and it will get you direct access to one of the actuator rods. If your handle is not working either a rod popped off (rare) or something is broken and you need a new handle anyway. Check out the pics on their website:
https://www.carparts.com/details/GMC/Sierra_1500/Replacement/Tailgate_Handle/2014/SLE/REPC580753.html?TID=gglpla&origin=pla&gclid=Cj0KCQjwjpjkBRDRARIsAKv-0O0kT3vJBo387OffWBoiCldke1-2_i64iuhmu9M5Enjz40l0t18GAiAaAl0IEALw_wcB&gclsrc=aw.ds
59 minutes ago, Racindave said:
Coat hanger to pull open latch on bed cover? Not sure what type of bed cover but seems doable my backflip.
i have the same cover. this is a known option and least destructive solution to get the cover open.
good luck
    • Are we talking about the same thing, though? The 7 versus 3 wear metals was from Lakespeed's 3.0-specific oil brand comparison test between AcDelco oil and Mobil ESP. The filter remains a constant so whatever excess particles the AcDelco oil is producing aren't being filtered out.   I'm assuming there's a parallel comparison to be made; IF the filter can filter down those particles, engine life increases, and your graph makes the case that a better filter (lower micron rating) can increase engine life. Introducing fewer particles AND filtering those particles with higher efficiency is the best of all worlds. Good oil, good filter.   Where we may disagree is the "baseline relative engine life". I'm more apt to believe the base engine life value is 200k+ on very average oil and filters, "bulk oil of unknown brand and white-label generic fleet-grade filter, Jiffy Lube"   Going from a 10 micron filter to a 5 micron filter should boost a base 200k to 275k in a vacuum as a single factor alone.   Here's the whatabout: How does regularly changing the oil and filter ahead of recommended schedule influence baseline engine life? Most people aren't going to science the heck out of this stuff or ask about Micron ratings, HTHS, or wear comparison tests at Jiffy Lube. Most of the Jiffy lube techs would say they need to call their tech support line to even try to get an answer.   --   Because we love anecdotes here, when I was fishing for 4.3 parts at a local yard this weekend, ALL of the 4.3 vehicles had well over 200k. I love looking at odometers of junked vehicles. How far did THIS go before landing at the crusher? The ones that still had engines weren't seized. None of them were vehicles I'd consider were Amsoil queens, in fact most of them had some kind of service cling-sticker in the corner of the windshield indicating it probably had very average maintenance services. Even the fresh parts rigs- I'm not sure taking an S/T series to 400k has much value considering the running value of those vehicles was probably somewhere around $1,000. 25+ years is a good run on time alone.   The intake manifold I salvaged had clean and bright pool areas. As expected, I found the fuel lines in the manifold rubbed through, just like mine. I'm guessing the lines on that donor truck started leaking, the truck started running rough, and its owner said that's enough I'm unwilling or can't take it out of service for several days, or spend $1000+ to repair it at a shop, it's simply time for a newer more reliable vehicle (or, more than likely, this is the 2nd, 3rd time this has happened in the truck's lifetime). While I don't count on my Blazer for reliability, the thought of giving it away for parts at certain points during my adventure, and being mentally free from its needs has has crossed my mind. I'd be losing $1500 or so, but I can only make more money; not time.
    • still $4.00 85 oct.
    • Always here to help. Discount Code: TIFF5OFF
