Can any T1 non NHT owners confirm that the 9.76” rear end is installed on their truck if equipped with the 6.2L? It is stamped on the rear end by the yoke. My dealer has no idea? ? My 2016 AT 6.2L has the 9.76” but before I pull the trigger on a new AT4 I want to confirm the 6.2L still gets the 9.76” rear end. Thanks!
I have NHT, but from everything I’ve read, all of the 3.23s are 9.5. They have two different suppliers, GM and AAM. Different RPO codes but both listed as 9.5.
Only max trailer tow package gets the larger rear end
On the reel- you are mistaken in regards to the 323 gears being only in 9.5
My 2015 High Country has the 6.2 liter engine, the 8 speed trans and 3.23 gears in a 9.76” rear diff case. I am absolutely certain of this.
That’s fine, but we aren’t talking about a 2015. This is the axle list for T1s.
8.6" axle 3.42 gear - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
9.5", Ratio RPO GU5 3.23 gear, Supplier RPO code SU7 - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
9.5", Ratio RPO GU5 3.23 gear, Supplier RPO code SU8 - 10-4122 / 19368514 Dexron Low Viscosity 75W-85 (GM)
9.5", Ratio RPO GU6 3.42 gear - 10-4091 / 19300457High Efficiency 75W-85 (AAM) - With 6 speed auto ONLY.  WT/Custom/CustomTB.
9.76" rear axle 3.42 gear - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
*Note.  Must ID the RPO codes to match proper fluids due to there being two different axle suppliers, GM and AAM.
Directly straight back from the pinion yoke stamped on the casting.
This would seem to indicate that you only get the 9.76 with NHT which is the only V8 option that receives a 3.42 gear using the new engine and trans combos ( carry over AFM WT 5.3/A6 combos still get 3.42) Looks like all 3.23 trucks both 5.3/6.2 and A8/A10 get the 9.5” axle.
I don’t really see this as a problem though. 9.5” is plenty of ring gear for most
I suspected this is how it would turn out.  When I bought my truck, I was led to believe that the 6.2 liter trucks came with the 9.76. I can only be certain of mine.
if it still holds true - 3.73 is the largest gear that your 9.76 rear end will accommodate without changing back to a 9.5 carrier and an “adapter” bearing set.
Edited by Darksky
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 675 Guests (See full list)
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
