Couple Questions New Trailboss
SO I am picking up my trailboss today coming out of my 2016 midnite.  Couple Questions maybe some people can help me answer and the MODS begin
1-I am going to be replacing the muffler.  Does anyone know the inlet and outlet of stock muffler.  Thinking about either putting in BORLA Attak muffler or Carven TR.  I can just swap out the mufflers and do not need to do anything else correct?
2-I have an AFE Cold Air Intake on my 5.3 and my new truck is also a 5.3.  I called AFE and gave them part number of the CAI currently have.  They said it will fit on my new 2019 5.3 with no issues.  Is this correct as I have read on forum that the 2019 has a different setup?
3-I am wanting to put my speaker box from my 16 crew cab into my 2019 crew cab.  Will this fit or because a new body style will I have to get a new box?
Thanks for the help in advance,
2.) The air box on the new trucks is in a completely different location than the K2s.
3.) If the speaker box just lays under the seat it might fit but this cab is completely different than the K2s so the floor contours will be different along with the length of the seat cushion.
Sent from my ONEPLUS A6013 using Tapatalk
As stated above.... No.  Entirely new Air intake design on T1.
Here is the GM intake for the 5.3 T1
1) muffler inlet and outlet are both 2.75"
2) As others have said no, it is completely different.
3) Not sure
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,043 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
