i put LEDS in my elevation no problems, and also in my 2500 LT again no issues........ton more light and cleaner
There's some funky magic going on with these LED lights.  I went to check the fluid.  They looked dry and I couldn't find a way to refill them.  They aren't like the old halogens.  There's no space for the fluid to be stored.  Same with the turn signals.  Somebody help!  I couldn't find anything in the owners manual.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
