2015 Z71 Help
I bought a 2105 Z71 2 weeks ago.it has a rc 3.5 lift with the 2.0 struts.stock uca and stock knukles.the lift was made in july 2018 so it hasnt been on the truck long(found sticker on block).i want to remove or change it but i have none of the stock pieces would have to buy new bolts and blocks..if i leave the 3" blocks and the diff drop installed what would be the best for the front?i will have to buy new struts to level so may purchase a set of 5100.
I ran Bilstein 5100s with the snap ring at lowest setting on my 2014 with a 2" spacer up front, nothing on the back. It leveled the truck. I know now that the ideal solution would have been 4600s with the spacer.
What exactly are you trying to do? Level, lift, or return to stock height?
Sent from my SAMSUNG-SM-J727A using Tapatalk
trying to get rid of the rc lift.looking for something up front that would match up with the 3"blocks in the rear and retain diff drop.would like to have some of the rake back also.
