1 hour ago, Lsgun1 said:
From what I'm reading the JL is supposed to be pretty bad ass. Subs meant for small space encloures and the box is all fiberglass. If it was $500 it would be a lot more appealing since it still needs an amp.
Subs also need a certain amount of space between the cone and loading wall aka the floor in this instance.   So i think it is going to sound muffled and wont allow for full extension.
I bought a custom made box from a member on here well over a year ago to replace the factory bose one. I believe I got one of the last ones he made before he stopped doing it. Too bad though because quality, customer service, instructions, and price were all great. I put a JL w8 powered by an Alpine amp (with a rux knob) in it. Sounds amazing paired with the factory Bose speakers. I'm very impressed with how hard it can hit when you crank it up. Sounds very clean and crisp at normal levels. Very glad I did it...
Chris do you have any pics? That w8 is a decent sub and it might be a fun project adding 1 in the center console before I throw a couple subs under the back seat. Plan for right now is 4 DD 506'S but I might buy 1 now to throw in the console spot
Edited by Bohanan23
Hello all, I’m new to this forum so be kind f I’m posting this in the wrong place. I’ve recently bought an 05 Yukon a and it turns out that the previous owner cut the entire wire harness I guess the OEM white harness and now I’m stuck with nothing trying to figure it out I don’t know which wires go where her 30 minutes the choirs or what the case may be and if anybody has pictures and diagrams or any input as to where to even begin please advise I’m almost ready just to my entire wiring harness for the entire vehicle I’m hoping it doesn’t come to that thanks guys
You need to go to the 99-06 section
On 5/1/2019 at 9:34 PM, Nasty said:
After talking with a buddy. I dont think im going to be using this enclosure in my truck. So when it shows next week its going uo for sale
what did he say that turned you away from it.
Direction of the sub matters and downfiring like that wont give me what i want
The center console box i ordered just showed up and its going right up for sale
Give it a try. You might be surprised
Gonna have to pass. Its already io for sale. I know it wont do what i need it to
  • 2 years later...
Huntr1117 did you add and amp with that new kicker sub or just use the oem one? Thanks
On 4/30/2019 at 9:27 PM, huntr1117 said:
I dont have a JL box but I did get an aftermarket box off Ebay that replaces the factory Bose sub in the console with an 8" sub. I removed my 10" sub box that I had under my rear seat so I could reinstall my underseat storage box. The 8" in the center console sounds so much better than the 10" under the rear seat. It doesn't rattle and just sounds clean.8d554e799c65eef8300a6e1b7a84e67b.jpga1f1451d93938a60f81b0fc5472dee32.jpg45de39fa8de543558fbca9a75b2b6378.jpg64cd20bef03d2594e8dbd15584e6f9f0.jpg
Sent from my SM-G975U using Tapatalk
do you know the dimensions and volume of this box?  I don’t see it in ebay anymore and will build one.
  • 2 years later...
On 4/30/2019 at 11:34 PM, rah7777777 said:
I’m in the middle of installing that eBay box now with a kicker 8”. I bought his full kit with the kicker Amp.
I haven’t found the box on eBay yet, but I’m still looking. How did you like everything after your install. And what amp and sub did you install? Thank you for any help.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
