1 hour ago, Lsgun1 said:
From what I'm reading the JL is supposed to be pretty bad ass. Subs meant for small space encloures and the box is all fiberglass. If it was $500 it would be a lot more appealing since it still needs an amp.
Subs also need a certain amount of space between the cone and loading wall aka the floor in this instance.   So i think it is going to sound muffled and wont allow for full extension.
I bought a custom made box from a member on here well over a year ago to replace the factory bose one. I believe I got one of the last ones he made before he stopped doing it. Too bad though because quality, customer service, instructions, and price were all great. I put a JL w8 powered by an Alpine amp (with a rux knob) in it. Sounds amazing paired with the factory Bose speakers. I'm very impressed with how hard it can hit when you crank it up. Sounds very clean and crisp at normal levels. Very glad I did it...
Chris do you have any pics? That w8 is a decent sub and it might be a fun project adding 1 in the center console before I throw a couple subs under the back seat. Plan for right now is 4 DD 506'S but I might buy 1 now to throw in the console spot
Edited by Bohanan23
Hello all, I’m new to this forum so be kind f I’m posting this in the wrong place. I’ve recently bought an 05 Yukon a and it turns out that the previous owner cut the entire wire harness I guess the OEM white harness and now I’m stuck with nothing trying to figure it out I don’t know which wires go where her 30 minutes the choirs or what the case may be and if anybody has pictures and diagrams or any input as to where to even begin please advise I’m almost ready just to my entire wiring harness for the entire vehicle I’m hoping it doesn’t come to that thanks guys
You need to go to the 99-06 section
On 5/1/2019 at 9:34 PM, Nasty said:
After talking with a buddy. I dont think im going to be using this enclosure in my truck. So when it shows next week its going uo for sale
what did he say that turned you away from it.
Direction of the sub matters and downfiring like that wont give me what i want
The center console box i ordered just showed up and its going right up for sale
Sent from my SM-G955U using Tapatalk
Give it a try. You might be surprised
Gonna have to pass. Its already io for sale. I know it wont do what i need it to
  • 2 years later...
Huntr1117 did you add and amp with that new kicker sub or just use the oem one? Thanks
  • 1 year later...
On 4/30/2019 at 9:27 PM, huntr1117 said:
I dont have a JL box but I did get an aftermarket box off Ebay that replaces the factory Bose sub in the console with an 8" sub. I removed my 10" sub box that I had under my rear seat so I could reinstall my underseat storage box. The 8" in the center console sounds so much better than the 10" under the rear seat. It doesn't rattle and just sounds clean.8d554e799c65eef8300a6e1b7a84e67b.jpga1f1451d93938a60f81b0fc5472dee32.jpg45de39fa8de543558fbca9a75b2b6378.jpg64cd20bef03d2594e8dbd15584e6f9f0.jpg
Sent from my SM-G975U using Tapatalk
do you know the dimensions and volume of this box?  I don’t see it in ebay anymore and will build one.
  • 2 years later...
On 4/30/2019 at 11:34 PM, rah7777777 said:
I’m in the middle of installing that eBay box now with a kicker 8”. I bought his full kit with the kicker Amp.
I haven’t found the box on eBay yet, but I’m still looking. How did you like everything after your install. And what amp and sub did you install? Thank you for any help.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
