Swapping out center console
Does anyone know when a service parts catalog will become available? I got the RST trim and didn't realize the center console infotainment unit and rear camera were not HD. I'm looking to swap out for the HD models that come with the higher trims or packaged trucks. Any insight?
My RST has HD radio and HD rear camera but you need convenience package II to get HD.  That may be a big undertaking and $$$$ to convert that over to HD though.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
