Decisions, Decisions. (tires)
Sinkhole
Hey all. So my RC 2.5 lift arrived and I have been contemplating which and what size tire to go with. I will be running them on the stock 18" wheels on my 2015 Z71 Double Cab.
As for size I was considering LT275/70R18 or LT285/65R18. I pretty much settled on the LT285/65R18.
On my 2005 I had a set of Goodyear Silent Armor P285/70R17 for 7 years and then a set Nitto Terra Grappler G2 for the last 3 years.
I liked both tires but found myself wanting something with a bit more aggressive look. I do a lot of city driving and don't wanna compromise too much ride quality and don't want a lot of noise. So no Mud Terrain tires.
I considering the following tires.
  • Goodyear Duratrac
  • BF Goodrich All Terrain KO2
  • Falken WildPeak AT3W
  • Nitto Exo Grappler
  • Toyo Open Country ATII Extreme
I would say the Duratrac or the KO2 are probably top of the list but I have heard so many good things about the Open Country ATII Extreme. Though it is the least aggressive tire looks wise.
So what your experience with any of these tires? Good, Bad, Indifferent. Rain/Snow performance?
Pics on a similar leveled/lifted truck might help.
Not sure if this will help you but I am also considering the top 3 on your list.
I  am basically 99% going to go with the Falkens because it looks pretty aggressive and has similar sidewall look to the BFG, it is cheaper, it has the snowflake symbol, and its P rated so still relatively light weight (I am a totally different tire size  tho 275/60/r20)
I don't know off hand what any of those tires are in the size you are considering (P, LT, E).
I  believe my sisters boyfriend has the Toyo AT2s, for about 1 or 2 months now.  Haven't heard any negatives from him.
I have 2” with the 285/65/18 ko2’s. Really like the ride. I too do a lot of city travel and haven’t had any issues. I got these with 5k on the truck. So 10k miles and mpg loss wasn’t too bad. This is lifetime average:
All the tires are LT285/65R18, Load Range E1. The only one out of the bunch that does not have the snowflake/mountain rating is the Open Country AT2 Extreme
I’ve heard the Duratracs are louder than people expect on the highway.
I’ve heard a lot of good things on the BFG’s KM3’s and a lot of positive feedback on them.
Here are my ko2s after approximately 10k miles. This is my 3rd set (not on this truck) and will be my next set as well.
  • 4 weeks later...
These run quiet?
I have the same tire in 325 x 60 x 20..  Very quiet tire for the size.
1 hour ago, ducklawyer said:
Yes very quiet for AT
Thanks for the input guys
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
