Best way to flush brakes
2015 Silverado Z71 LTZ, 6.2L V8. 114,991 Miles.
Coming up on my next brake fluid flush at 116xxx. Last time I did the ol' pump the brake pedal to cycle new fluid through the lines. That was kind of a PITA, so I'm inquiring about easier/more efficient methods. I know parts stores have the one man bleeder kits, NAPA has a reverse bleeder, and I've even heard about gravity bleed. Would there be any benefit to pumping the brake pedal with the truck idling to let the ABS pump do the work? Open to ideas.
Thank you!
3 hours ago, diyer2 said:
I just bought this from Harbor Freight.
Videos of it in use on You tube.
Waiting to try it.
https://www.harborfreight.com/brake-fluid-bleeder-92924.html
The ABS has to be cycled with a scan tool I believe.
I'm not going to worry about the fluid in the ABS circuit. Can't be that much IMO.
I have a Mighty Vac but I think I like this HF tool better. Fewer trips from under the truck. Thanks!
I have that HF one and used it few times. It worked great. Just remember not to send full PSI thru it.
It may say in the booklet how much PSI to use. The fresh fluid reservoir works nice.
Wowza the Gear Wrench tank looks sweet, lotsa coin for that though. The harbor freight system looks good too, but I don't have an air compressor. That Allstar performance bleeder bottle though, that looks like a handy little deal. Glad I asked! Thank you for the answers guys, looks like I have some shopping to do!
I use this: https://www.amazon.com/Motive-Products-System-Bleeder-Trucks/dp/B000TK9FE8/ref=sr_1_9?crid=1XG9H2OPRZCKU&keywords=motive+brake+bleeder&qid=1558956609&s=gateway&sprefix=motive+bra%2Caps%2C154&sr=8-9
I have adapters for our German cars and one for my boat trailer.  Works great, I end up using it at least once a year.
I got the Motive pressure bleeder setup for my truck, initially with the plastic cap for the reservoir.  Pumped the tank up to the pressure that GM's FSM says to use, it worked briefly, then the cap blew off the reservoir and sprayed brake fluid all over.  Continued doing it, at a lower pressure (about 10-15 psi or so IIRC), and then the plastic cap stayed on.  I did buy Motive's metal cap after this, and that does hold at the pressure GM has in their FSM (25 psi I think, it's been awhile).
It's been 3 years or so, so it is time for me to flush my brake system...
The only real problem I had, was that for whatever reason, Motive was utterly incompetent at putting the correct address on the label to send it (the metal cap, purchased separately) to me.  I literally had to scan a piece of mail from someone else, and email the scan to them, before they could/would figure out how to make a label with my correct address (they sent it out, then it was returned for an addressing problem 3 times before they finally got it right).
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 517 Guests (See full list)
