2020 3.0L Diesel Maintenance Schedule
Anyone seen or can link to the maintenance schedule for the 3.0L diesel.  To get an understanding of gas vs diesel maintenance.  As well start for one to understand high level cost implications.  Service oil change duration on non heavy cycle and liters per change would be appreciated..
7500 miles for the oil change 10L of oil I think. The oil pump wet belt is 150k service. The timing chains don’t need to be swapped out or serviced. Air filter every 25-50k? Miles mabe. No spark plugs so that’s a plus? there is a three with the 3.0 engine specs lots of good info in the video
Normal Schedule:
Oil change:  7,500mi/12,000km.
Engine Air Filter:  45,000mi/72,000km. Or every four years, whichever comes first. If driving in dusty conditions, inspect the filter at each oil change or more often as needed.
Cooling System:  Every 5 years or 150,000mi/240,000km.
Inspect Drive belts:  150,000mi/240,000km or every 10 years, whichever comes first. Inspect for fraying, excessive cracking, or damage; replace, if needed
Oil Pump Belt:  150,000mi/240,000km or every 15 years, whichever comes first.
Fuel Filter:  30,000mi/48,000km Or every two years, or when the CHANGE FUEL FILTER message in the Driver Information Center (DIC) comes on, whichever comes first. The fuel filter may need to be replaced more often based on biodiesel usage, driving in climates with severe dust, off-road driving, or towing a trailer for extended periods.
Severe Schedule:
Automatic Transmission:  45,000mi/72,000km.
The GM oil is $8.62/qt MSRP, takes 7.  Obvious other expense would be DEF but that's 5 gallons about every 5000-8000mi depending on consumption.  Fuel tends to run in the low $3/gallon, at least in NY.
