Picked up my first truck the other day. 2019 Sierra AT4 which came equipped with the kicker boombox in the tailgate. It's bluetooth connection is very poor. It normally takes me several tries to turn my phone's bluetooth on and off as well as cycling the boombox pairing on and off to get the thing to sync.
Once it is synced, I can start playing a song on Amazon music, and without fail within 2-4 seconds the bluetooth disconnects. I've tried on my iphone as well as my wife's droid and both do the same thing.
I can connect and play music through youtube, but as soon as I hit the volume + button 3 times the bluetooth disconnects. It's fine with one or two hits, but on the third hit it craps out every time. Total waste of money in my opinion and the dealership has no clue how to fix it or if it may need a software update or something.
Anyone else have the same issue?
  • 1 year later...
My tailgate speaker worked fairly well before, but now I can't even get it to turn on. The connections and fuses seem ok unless I am missing one somewhere. Any ideas?
It sounds like an issue with the bluetooth receiver integrated within the Radio.  The following is the service procedure, but I would start with step 6.
Circuit/System Verification
Note: The MIT tool can be used to test either cellular phone or streaming audio functions. Refer to the tool instructions, and perform the appropriate test(s) related to the customers concern in the following steps.
  1. Verify no DTCs are present.
    • If no DTCs are present
  2. Verify the A11 Radio calibrations are current.
    • If the radio calibrations are not current
      Reprogram the A11 Radio and re-evaluate the concern.
    • If no update calibrations are available
  3. Ignition ON, infotainment system ON.
  4. Verify the infotainment system successfully pairs with the MIT tool.
    • If the infotainment system does not successfully pair with the MIT tool.
    1. Perform the 3 vehicle Factory Resets located in Setting>System>Return to Factory Settings.
    2. Verify the infotainment system successfully pairs with the MIT tool.
        Replace the A11 Radio.
    • If the infotainment system successfully pairs with the MIT tool.
  5. Verify the infotainment system successfully completes the desired feature test using the MIT tool.
    • If the feature test is successful but the audio is distorted.
      Refer to Speaker Malfunction
    • If the feature test is not successful
  6. Verify the customers device can be paired with the infotainment system.
    • If the device can not be paired with the infotainment system.
      Perform a reset on the device. Refer to device manufacture’s information.
    • Verify the customers device can be paired with the infotainment system.
      If the device still will not pair inform the customer the issue is with the device.
    • If the device successfully pairs with the infotainment system.
  7. Verify audio can be heard while streaming from the device.
    • If audio can not be heard while streaming.
      Ensure the volume on the device is turned up to an adequate level.
    • If audio can be heard while streaming.
  8. All OK.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair.
Control Module References for radio replacement, programming, and setup
I can even get mine to turn on? The harness behind bumper was half unplugged. Plugged back in. Still wont turn. Any ideas?
Needs to be replaced
Nothing to do with truck infotainment
That’s a kicker module not a GM one
I can't seem to find the fuse for trailer accessory power if one exists, but the in-line fuse at the t connection is good and everything is plugged in. Seems like the unit itself may be toast.
  • 1 year later...
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
