Dark tail lights?
1 minute ago, jpinoy said:
I have a stubby on mine and there is no difference in reception between the factory long @$$ one. You just have to get the right one(I love Amazon return policy) But with that said, I mostly stream music, so even if I had a crappy one, it won't matter, I've always replaced those coat hangers that come from the factory.
Sent from my SM-N950F using Tapatalk
Not to derail this further...there are probably already 20 pages of posts in the T1 section alone from people saying that there is no loss in reception...but same here. No loss of reception and I do use AM and FM quite a bit. Just don’t buy a junk $10 Autozone one and they work just fine. Not everyone likes the stubby look but my factory one was all marred up like the dealer installed it with a pipe wrench, so good riddance.
In regards to the taillights, I think a light smoke would look good and not compromise anything significantly. I’ve seen it taken way too dark by a few people (probably the same people who tint their windshields) and I don’t care how many LEDs are in there, you’re gonna lose some light transmission.
On 8/2/2019 at 8:08 PM, Mbcorry said:
Has anybody had lucky darkening tail lights?
Rear tail lights and 3rd brake light are blacked out. hope this helps.
Got a pic with tail lights and brake lights on?
Those look good....
Those look good....
I'll snag some pictures once i'm off work. I just took those after i had the work done.
Those look good....
Couldn't get the brake lights, as i am just one man, but here's the running and reverse lights.
Looks great. Flashers work too but this should give the naysayers something to reference back to when they say it’s too dark for taillights.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
