Dark tail lights?
2 minutes ago, tbarn said:
So you can get rearended?
I see people do a lot of dumb things and this is in the top few on the list.
With the current LED setups, I don’t see this being an issue. I’m planning on doing this to my AT4’s headlights, taillights and fogs. I’m going with light smoke however.
I’ve learned there are a lot of fuddy duddies on this forum. [emoji849]
I'm not talking about painting them with black paint. I'm talking about a light darkening. In my years as a cop, I've never met somebody who rear ended another car with slightly darker tail lights ?
Ain't that the truth.  I've noticed that about all truck forums unfortunately.  Everybody is a genius and everybody knows everything on these things ?
I agree with the LED taillights and maybe fogs, those can be seen as opposed to halogen. I was behind a black LTZ today, his taillights were blacked out, looked normal and when the brakes were applied, bright as well. Might do that to mine as well after seeing how well it can be seen.
Also depends on how dark you tint them as well. Now, I personally wouldn't do my headlights [emoji2369][emoji1]
Sent from my SM-N950F using Tapatalk
I am old really old still thinking about tinting my taillights on a black AT4. I like the headlights and fogs so I will leave those but don’t get me started on 5 inch offsets and stubby antennas that look like a little penis.
Here you go for the differences in headlight tint and how it impacts light output. Not my video, just an example.
http://
2 hours ago, Mbcorry said:
Has anybody had lucky darkening tail lights?
I darkened mine with VHT night shades. 2 coats
I installed one of those small antennas on my T1 today.  Nice to make it less obtrusive.
So when you look at an OEM antenna do you think of a long skinny penis?   ?  Not judging of course.
Stubby antennas as seen on a lot of vehicles who had them from the factory get away with a stubby antenna because of a preamplifier boosting the signal received. But the Pickup truck with a short antenna stuck on the factory mount by the front fender? NOT SO MUCH. They replaced it based on looks and now have shitty performance.
Sent from my SAMSUNG-SM-J727A using Tapatalk
A friend that works for a body shop uses clear coat with a couple drops of black paint to give it a darker look while being completely safe still. You just need the right person doing it or have the means to do it right.
Like said the LED tail lights are the key to being safer, they are so much brighter. Like this example picture.
97215d1371447187-g37-coupe-tail-lights-p
I have a stubby on mine and there is no difference in reception between the factory long @$$ one. You just have to get the right one(I love Amazon return policy) But with that said, I mostly stream music, so even if I had a crappy one, it won't matter, I've always replaced those coat hangers that come from the factory.
    Sdid
    Sdid
  • Who's Online   7 Members, 0 Anonymous, 1,489 Guests (See full list)
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
