2019 - New Wheels
Just bought a 2019 Silverado 2500HD that came with the boring 17" rims. I bought a set of 20's that came off of a 2018 2500, wheels and tires both. When i went to have them swapped out, the guy at the tire shop said the sensors in the 2018 wheels are different then what i have in my 2019 and that it would trigger warning lights and wouldn't program correctly. He said something about an "auto-refill" that was added to the 2019's. Something like that. Their fix was to tear apart both wheels and tires and swap the sensors, which was going to cost me, with labor, about a grand. Does this sound right to anyone? Or has anyone come across this before? Not sure what to do next
The sensors aren't compatible 18 to 19, but that aside, theres no way that should cost much more than $100 or so.
$1000 is laughable. There is nothing besides labor, as a part of this job. Break down the tires x2, sensor removal x2, reseat the tires x2, and balance tires x2. Bit of a pain in the ass but any tire shop will do this for you.
A $1000 for dismounting 8 tires to swap sensors?  Find a new shop ASAP.
Take it to your local Chevy dealer and try having them learned.  2018 to 2019 HD its still the same sensor and should be the same frequency so they should work no problem.
The new body trucks are the ones that changed frequency.  HD 2019 is still the 2015-2018 style.
Don't even have to dismount the tire. I have R&Rd sensors and I just deflate, use a high lift jack to deseat the outer bead, reach into the tire and remove the sensor then air up to reseat.
On ‎9‎/‎24‎/‎2019 at 2:47 PM, Libtech29 said:
Thanks tanner, i will have to search around for a different shop and get some prices
Any updates?  Hoping you saw my first reply to this post.
9 hours ago, Libtech29 said:
Talked to the dealer and they said they can’t reprogram them. Gonna have to swap them out. Better news is they said it’s only $150 to do it
that's better lol
Perhaps your truck is on the 433mhz frequency?  Most every 2015-2019 HD I've seen run the same 315mhz sensor.  Did they try a TPMS relearn?
I had to schedule an appointment for Monday afternoon. I will be asking more questions to them face-to-face and get a better explanation. I'll give an update after the appointment
2019 HD's also get the - 'tire fill alert', according to the order guide.
(could have changed part way thru model year)
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
