Brake Caliper Replacement / Upgrade
Darksky
I did an brake job about ten thousand miles ago. But, did not replace my calipers, they seemed fine, moved well, didn’t appear to have any galling. That has bit me in the ass. I have a front brake dragging on the inside of the LF disc.
I will attend to it this coming weekend. Does anyone have recommendations for replacement calipers? I’m not looking to upgrade to a Big Brake Kit. Just replace the calipers with something OEM compatible.
IIRC correctly, someone had posted about swapping to a Suburban’s brakes for larger/better performance. I’m curious about that as well. But for the moment, I need a source for “good, better, best” quality replacement calipers.
Thanks, Dark
Previous gen trucks had the rear brake upgrade with the suburban rear calipers but the front were the same.
That will be the same way here, the front brakes calipers aren't going to be any different between the half tons. I even researched the part numbers. Both the silverado and suburban run the same AC delco caliper part number.
You can buy a brand new reman AC delco caliper from Rockauto for $43, but then you get the $60 core charge and you have to ship your old one back to get your core fee back.
You could go to a dealer and see what they charge or hit up a local parts store and get one there. Napa rebuilds factory calipers and if the warranty hasn't changed, they are a lifetime warranty.
The caliper brackets  have much more problems than the actual calipers. Make sure the slides are free and the rust is cleaned from behind the abatement clips. I work at a GMC Buick dealer and we stock the brackets by themselves because we change much more of those than the cailpers.
I will look at the brackets. Thank you.
Power Stop is selling a reman set of their “performance” calipers for $160. That seems like a helluva lot for a red powdercoat job on a set of standard remans.
do the brackets suffer other problems? Like being bent/warped? What else should I look for?
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
