2018 Silverado rear u-joint failure.
Hey guys. For the past few weeks i been noticing a chirp/squeel noise from my truck while on a 1600km roadtrip home, Not long after making it back to this turned into a vibration, which immediately i knew was a U-joint. Just not what i expected from a year old truck with only 27,000 km's.
Anyways, the dealer here in town are not at all cooperative, and unable to fit my truck in for over a month they claim, I have tried ordering the u joint from the dealer which is a process that seems to be taking forever. I have tried calling around and searching, does anybody know a cross reference for a aftermarket u-joint at the least so I'm able to get my truck back on the road as quickly as i can? My truck by the way is a 2018 Silverado (Canadian) CCSB, 4X4, with the 5.3.
Thanks!
Mark
Thanks!
Mark
Just go to a auto parts store and get one there very easy to do and not expensive if your in a hurry. https://www.autozone.com/drivetrain/u-joint
Check with an autoparts store. It’s not the dealers fault they can’t get it in, it’s the UAW and their stupid strike causing the issue. U joints don’t typically fail that early but if you figure they make a few million of them, a couple will be bad here and there.
It’s not difficult to do it yourself, myself and others on here I’m sure could walk you thru it.
Yeah, local parts store if you need it right away, online if you can wait a bit for likely a higher quality, but still cheaper part.  if you use rockauto.com, make sure to find the 5% off code and put it in when you checkout.
I have no issue at all replacing u-joints myself (im a certified mechanic myself) just seems all the staff at local parts stores here have no idea how to cross reference part #'s. I got the OEM part number on hand and managed to cross it up last night so i'll check around today and let you guys know how it goes!
Please make sure you get the proper Spicer U joints for you truck with several size color coded clips included and also the caps are made of the right metal that won't corrode with aluminum There is a real science to changing these modern U joints
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 2,944 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
