On 11/23/2020 at 9:31 AM, edgexcsp said:
My 2021 pulls to the right w/ just a hair over 500 miles on it, at first I thought it was me but it is definitely the truck.  I have to hold the wheel a degree or two to the left in order to drive down the road straight.  I am headed into the dealer tomorrow to have the alignment checked.
Wish me luck!
I just got my 2021 Chevrolet 2500 4 days ago.  I noticed it slightly pulling to the right.  At first I thought it was me or the crown of the road "pushing" it to the right but, on a flat road or if I move to the other side of the road it still pulls to the right.  I'm going to take it in in the next day or two to get it checked/re-aligned.
Have a 2020 2500 with a service body. It pulls to the left, i have to hold the steering wheel at 1-2 oclock to keep it going straight. It will take the truck up over the crown of the road and into oncoming traffic. The first alignment was done at 1500 miles and everything was in spec. Local dealership billed me for the alignment even though the truck still pulled. They tried to claim that the wear in the road was causing it. If i wanted them to keep looking into it i would have to pay for the parts replaced. They clearly dont know how to diagnose an issue. Took it to them to have the first service done, at my request, they moved the tires from side to side not front to rear. The truck would still pull to the left.
Took the truck to a different dealership at 5300 miles. A friend works at this shop but they dont have an alignment rack. He test drove it and saw exactly what i was talking about. Checked the rotor temps and they were all within 5 degrees of each other, indicating that the calipers are no dragging. Put the truck in the air, all the tires turned freely. He said to take it down to the chevy dealership down the street. It had its second alignment. Once again, everything was right where it is supposed to be. GM tech support is now involved. They are recommending the steering angle sensor be recalibrated.
The tires on mine make a noticeable difference. After my first rotation, the truck was constantly pulling left as described. After the following rotation where the front tires were returned, it was centered again. I have rotated the tires 3 times and each time i bring the rear tires to the front, it pulls.
Sent from my SM-G981U using Tapatalk
  • 3 months later...
Just picked up my new 2021 3500 gasser yesterday. Drove it 5-1/2 hours home and noticed it definitely pulls to the right. Had to hold the wheel a couple degrees to the left to go straight. My issue is I had the dealer put different tires on it for me before I picked it up. I stuck with the factory size but went from the Michelin LTX at2’s that came stock to the BFG K02. I emailed the dealer right away this morning to ask if anyone drove the truck after putting the tires on, he said he would check. I told him I was concerned that if I brought it in to have it checked they wouldn’t cover anything because of the different tires. He told me to go ahead and get it checked and if there was a charge they would cover it. So I guess I’ll be dropping mine off too.
Be sure to have them check your alignment. Mine had significant steering issues that were all corrected with a proper alignment.
check the alignment. also, I noticed my truck started a decent pull right as soon as I put the BFG KO2s on it. granted they are 20mm wider, so the contact patch is bigger. I am really starting to think these tires have a radial pull to them
So the first dealer I brought it to mentioned nothing about the tires so that’s good. However they drove it and tried to tell me it was normal. They checked all the suspension parts to make sure everything was tight but didn’t check the alignment. So I brought it to a different dealer on Friday and they could tell it was just driving it out of the entrance bay into the service bay. So they reset the alignment with the steering wheel straight. Unfortunately whoever did it over corrected it so now the wheel is off the other way. So it’s going back in on Tuesday
Just now, finn5033 said:
So the first dealer I brought it to mentioned nothing about the tires so that’s good. However they drove it and tried to tell me it was normal. They checked all the suspension parts to make sure everything was tight but didn’t check the alignment. So I brought it to a different dealer on Friday and they could tell it was off just driving it out of the entrance bay into the service bay. So they reset the alignment with the steering wheel straight. Unfortunately whoever did it over corrected it so now the wheel is off the other way. So it’s going back in on Tuesday
Sounds familiar. Not sure if these trucks are tough to align, by my dealer did the same thing initially, then tried again and made it worse. They paid to have it done at an outside alignment shop and finally got it right!
Had the truck back in today, they got it fixed correctly this time. Steering wheel is straight and truck is tracking the way it should.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
