Camper shell wiring on 2017 Silverado
I'm new to this forum but an old (very old) hand at DIY repairs and installations on vehicles since the mid  1950s.  I have searched u-tube videos and this forum for wiring source information to wire the 3rd brake and interior light in the cap I just put on my '17 Silverado 1500.  The question is, where can I connect to existing wiring near the back of the bed for the needed lights?  Is that connection available?  II not, why has no one suggested splicing into the existing high brake light circuit and the cargo light circuit ?   I have found videos for every truck except late model GMs.  Some are very amateurish and not even good advice.  This isn't Rocket Science and I think my suggestion above will work but am I reinventing the wheel???
On my 2016, I had added the OEM bed light kit. It plugs in appx behind the license plate under the rearward part of the bed. The lights get activated by the cargo light switch. I bought a Century cap and when they installed it, they removed the left taillight and tapped into the wires for the bed lights for the interior light on the cap. I just leave the cap inside light switch turned on all the time and control it with the cargo light switch. I'm not sure what they did to access the brake light but I am fairly certain that it is tapped somewhere by the left taillight also.
There is a separate connector in the junction box (behind the rear bumper) specially for the 3rd brake light.
I have a camper shell on my 2017. When my wife gets back with the truck, I'll grab you the wire colors that the harness is tapped into.
Go to gmbodybuilder.com and pull the circuit info from there.  There were sealed terminals in the under-bed junction box on my ‘14 for brake and bed lights (if you don’t have the factory bed lights -which I did).  I would assume they did the same on the ‘17.  You just need to buy the correct terminals and seals (avail on amazon) and a terminal tool to remove any terminals (if you want to dbl up any existing wires).
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
