So I installed a GM cold air intake about a month ago and had the dealer load the tune. Since the “tune” was loaded the truck’s fuel mileage dropped 2-3 mpg and the check engine light keeps coming on. Each time the light comes on my Onstar states an emission related issue. The first issue was a vacuum leak at the MAF, then the next was an O2 sensor that needed to be replaced and who knows what it is now. Is it possible the dealer did not load the correct tune into the ECM when the CAI was installed? I would be interested to hear everyone’s thoughts on this issue.
Any chance you sprayed anything on the mass airflow sensor while you had it out? Or does the CAI come with a new one? They can get messed up if you spray brake clean or anything other than MAF sensor cleaner on them... Just a thought.
Sent from my Pixel 4 XL using Tapatalk
No issue with my CAI nor exhaust.  I did not like that GM CAI does not provide a rubber seal for the MAF to the new CAI housing but if there is any leaks there I cannot imagine it would trip a code.  I always go back to the last thing that changed.  If you had no issues prior to the dealer flashing the ECU, I think they did a bad flash and would start there.  That definitely would not be the first time that there was a communication issues during a flash but they should have caught that.
  • 3 years later...
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
