Wheel alignment ? Tire issues ? Suspension ?
So my new truck started making some wicked loud rumbling noise so I took it to the gm dealer thinking it was a wheel bearing go at 12000 km tho didnt do anything besides my oil change and tire rotation as requested but didnt check anything else, so when I took my truck the noise went from a 10 to a 8 and i just went on i dont have time to be sat in the garage all day.
So now i am at 21000 km and the noise is so loud you cannot talk to the person next to you so i went back got a oil change my wheel bearings checked again and I was told that my tires have feathered and i needed a alignment,  why wasent I informant about this 9000 km befor on my last service right ?
So I went and got a wheel alignment and the toe adjustment was out to 0.15 of a degree on both tires,  so my question is this enough to cause feathering
I think I'm having the same issue. Tire noise seems to be getting louder.  The driver front tire is getting some feathering or chop. Every other inner tread is hi then low.
These tires are absolute junk. I’m having the same problem. Even as such where the vibrates causing other things to work loose.
Take your salesman/service advisor for a ride and let them hear the noise.  I suspect your noise issue is tire related and I have found  It is common for pickup tires to wear  on the outside edges first.   Regular rotation helps to slow down the need for replacement.   I'd negotiate with the dealer for a deal on new tires. (Michelin's are quiet)   Part of the deal would be for a refund if the noise persists!
Well they have all ready taken it out and said its noise from the tires because of feathering but the truck was quite as a mouse for the first 5 or 6 thousand kms and I do regular tire rotation as well
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 1 Anonymous, 4,143 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
