I have a 2017 SIerra SLT that is out of factory warranty. It has the factory LED headlight/turn signal modules. The drivers side front turn randomly will not work. Sometimes it won't flash on lock/unlock from the remote, other times after I start the truck it won't flash. The rear drivers side and mirror led's do flash,  just not the front. If I shut the truck off and start it up again that will normally fix it for a while.  I swapped the headlight control module between sides and that didn't help. I haven't been able to reproduce the issue enough to test swapping the entire headlight modules between sides. Any thoughts on what it might be or other things I could try?
Welcome to the site.
If you are still on your original battery, have it checked, or replace it
The new generation trucks do all kind of weird things when the battery starts to fail.
Thanks for the suggestion! I had the battery tested today and it was BAD! I put a new battery in and so far the turn signal has been working, but it will take a few days to know for sure. Crazy that may have been it! I can't believe it was just affecting the signal on one corner.
Edited by Sierra17
You are very welcome.
I agree, it is weird, but on the positive side, it gives you signs that it is going to fail, rather than just stranding you in the middle of nowhere.
  • 1 year later...
Any update on this? My 2017 started doing this last December when we were visiting Ohio. It hadn't done it all spring/summer and most of fall since then (we live in Florida). Just noticed this happening again randomly now that the weather has cooled down.
Edited by tpilews
  • 4 months later...
Just wanted to add more information to anyone looking with this same issue. I ended up replacing the battery, issue when up getting worse within 2-3 weeks of the new battery. The turn signal works about 20% of the time.
Another update... Dealership is replacing the fuse box. Said there was a bunch of water and corrosion in it. I'll get it back in a week and will provide another update.
  • 8 months later...
Did this fix the issue? I have the exact same symptoms.
This is certainly not what we like to hear, erschmidt.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: erschmidt/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
@GMCustomerService can you kindly explain how this post provides any kind of resolution so others can know how to fix their problem? The point of this forum is to provide help with solutions to fix problems. I have yet to see any of your posts do that
  • 4 months later...
I have a 2016 Sierra with the exact same issue and have had the issue since new.
It works good 95% of the time. I told the dealer about it when it was new but it never acted up when i was at the dealer so they did nothing about it. The only way i have found that resolves the issue temporarily is to turn off the truck, wait for all accessory lights to turn off than restart the truck and it always works after that. seems like its usually  first thing in the morning when starting it and i had a new battery installed not that long ago but its almost like when the vehicle charges up the battery ever so little it works better. I'm assuming its a sticky relay that needs optimal volts to operate correctly.
  • 6 months later...
Working on a 2015 Yukon with RR LED turn signal (RPO X88) no op.  No output from BCM to RR LED turn signal.  No problem with LR.  Inputs from turn signal and Hazard switches to BCM are good.  Continuity from BCM X4-4 to RR LED turn signal BN terminal is good.   OK BCM failed - replace.  Programmed and performed setup using GM SPS2 software on BCM.  Still no BCM output to RR turn signal.  Confirmed still no BCM turn signal output to RR.  What am I missing?  BTW - new AGM battery installed 2 weeks ago.
Edited by tblentrprz
FIXED!!!  8 fuses feed the BCM.  BCM fuse 6 (15A) bad.  Interesting - no codes stored.  No other circuits/function inop.  Glad this is done.  FYI - some good info from SD.
My issue did come back again after replacing the battery. It ended up being the entire headlight module! Such a disappointment, there was no way to replace just the turn signal portion. It is fully integrated into the module. I knew it wasn't the control module as I had swapped that from the other side. I finally replaced the entire module. It was the most expensive turn signal repair cost I've ever had.
I have this same issue now with my '17 sierra 1500. I had it before then it went away and is now back again with the cooler weather. I don't get how it could be the whole module if it just works perfectly some times. One would think if the LED was bad it would stop working for good. I haven't been able to find any differences in battery voltage when it is or isn't working, there is always power right up to the plug and I've swapped the control modules from one to the other before with no difference. Could a bad ground after the signal possibly cause this? Ive checked the one under the rad with no success. I can't believe they would make an entire headlight module that can't be serviced and want their customers to pay $1200 for a signal light 🙃.
    • yo-yo prices on the hi-way the last couple days, Sunoco was $2.75, went down to $2.74 then up to $2.81, the twin Gulf stations ( 1 on both sides of the divided hi-way, same owner) was $2.84 and went to $2.89, Mobil went down a nickel, $2.89-$2.84 and dropped the plastic price a dime, to $2.89,truck stop went up a nickel to $2.85
    • New tires are on, Cooper Discoverer Road+Trail AT's in 235/75/15. $100 per tire, after $10 AAA discount. Plus install ($100), disposal fees, and taxes.   The new tires ride nice. Catch 22, new tires, I love it again! But I feel like I've been through the wringer with this rig, and maybe I don't need this kind of headache right now. Wait until tomorrow, I'll probably love it again and keep it another week.   Never a dull moment: Got a CEL driving to the tire shop, P0172 bank 1 too rich. Oh lordy, really? I've been enjoying an emoji-free dash for too long, apparently. I popped the hood at the shop and I think there was a vacuum leak very close to the intake. Cleared the code and put a bunch of miles on it going home, code never returned. My fix was zip-tying the line on the vacuum reserve ball because the hose won't stay seated. It's either that or the fuel pressure regulator has an issue again or an injector is leaking. See why I'm getting tired of this one?!   In the gas price thread I recorded 19mpg on the last tank in fairly mixed driving and some higher-speed highway (70). I also don't have the lower engine shield installed right now, and that would help with diverting a lot of wind underneath the truck.   Not too long ago, a green '96 4-door 4x4 came up for sale with less than 1,000 actual miles. There was a story there but it was real, and the place wanted like $25k for it. Would be fun to have a NICE example of one of these, but not too nice. The joy is driving them.   That's it for a while...family and social stuff all weekend, no time to play with my Hot Wheels in the garage for the next couple of days.
    • $5.19 after Kroger discount for 87 today. Moses!   Somehow I've already put 560 miles on the Blazer with the last tank clocking 19mpg.
    • I have a 91 GMC SIERRA 1500 4.3 liter. My dipstick broke. Can someone tell me how long is the oil dipstick. Local Part stores do not stock the oil dipstick. If someone can tell me the length. I can match up an aftermarket one. Thank you.
