Rusty Hitch
 Just wondering what everyone does (if anything) to prevent rust building up on their hitches?
 Over the years I haven’t really figured anything worthwhile. I tried those oem rubber hitch plugs when I’m not towing, but I can’t say that they ended up doing too much.
 It’s always an eye sore to have a nice clean truck.. and then have rusty hitch sticking out of the rear end. I’m sure some people on here can relate lol
Today's hitches on the GM trucks are hidden, are you just talking about the receiver piece? The hitch moves in there a bit so it will take the paint off. What I do with mine is coat the hitch in grease and leave it in most of the time. If that is not the solution for you then just hit it with a spray bomb every now and again, then put some grease or oil on to prevent the rust from growing through.
Yes, sorry. I meant the “receiver”
Once it gotten to the point of looking bad I've always taken some sandpaper sanded the rust off and scuffed it up as much as I could and hit it with some Rustolium gloss black.  That seems to work for about a year or so then do it again.
+1.
5-10 minutes each spring: a wire cup on the cordless and a few coats of rustoleum and you’re good till next year.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,220 Guests (See full list)
