Touch screen icons
Does it do it every time you start the truck? Try pulling the radio fuses and put them back in, if that doesn't work disconnect the battery for 5 minutes and try again. If that doesn't work the head unit is probably toast.
  • txab changed the title to Touch screen icons
Mines did that about two weeks ago, it was 27degrees outside at 7am when I drove 45min to work (changed the station with the pads on the steering) everything worked beside the touch screen, by 9am it was working when I jumped back in the truck
