I purchased this product from Amazon Prime for $12.99: Auto Car Ceiling Roof Lights Dual-color Fixture with Universal USB.  It is a rechargeable LED round dome lamp. Works great accept that the double stick tape would not stay on my cloth headliner. I then installed a heavy duty 3M tape from Home Depot (with red backing). So far it has not come off. I would recommend these products.
On 2/16/2021 at 3:00 PM, kodiakdenali said:
Not sure if the dome behaves differently on different trims but on mine the BCM output does not turn on if you turn on the map lights individually, but there is also a manual dome light button on the overhead console, that one turns on all of the map lights front and back, it does turn on the BCM output which activates the extra lights. I like it very much this way. if I really want light I can push that button, but if I just need to see but don't want super bright light I can push the individual lights which turn on that one light only. the passenger can still turn on their light to see something without turning all of the interior lights on which would be way too bright at night time with the addons...it actually works great!
On 2/16/2021 at 2:52 PM, mandrewbot3k said:
Just wanted to follow up that the DPDT relay with a 100uF capacitor worked much better. There is less of a delay when switching from door assist mode to regular operation. Works well when applying the dome light manually too. It's a great upgrade.
  • 3 months later...
One interesting issue I had messing around with these mods is that when I did the overhead console mod, I had no problems just tapping the gray interior lamp control wire, running a ground and that was fine.
As a second mod I was going to add footwell lights, but BCM X1 pin 23 didn't seem to have any power when I checked it with a working LED I use for testing, even when the dome lights were on.   Pretty sure I had the right module it was the only one with gray wires in pins 21 and 23, and if unplugged it killed the interior lights.    In the end I just wired them into one of my upfitter switches.
Using a meter it does look like the voltage increases on the 23 pin when the dome lights are on, but it's a tiny amount like 0.1v that seems nowhere near enough to trigger a 12v relay.  Is anyone actually powering lights off this 23 pin wire, like in the overhead console, or only using it to trigger a relay?
Edited by todd308
  • 5 months later...
On 12/15/2019 at 11:18 PM, mandrewbot3k said:
Has anyone added any interior lighting?
It’s awfully dark inside the cab when I’m looking for stuff at night. Don’t feel like I should need a flashlight for my truck.
I feel like every other tick I’ve had had nice bright lights on the door near the kicker panel and could actually illuminate the cab.
Just curious if anyone’s added anything like led lighting below the dash or anything?
  • 4 months later...
I have been browsing this forum for about two months. I have finally just joined. So much great information and knowledge. I want to thank kodiakdenali, Arboc, Rook126 and 2020 SLT owner for your knowledge and experience for the interior lighting install. I have just completed the 11mm Oznium LED install in my TB and it has made a huge difference! I will try to start posting more regularly now that I am a member. Again thank you.
  • 2 years later...
  • 3 months later...
I have a 2024 1500 trail boss with base interior. I just tried the mod with the bolt lights, but neither gray wire in the right plug on the ceiling console gives any voltage when I open the doors. I don't understand how this can be possible because unplugging the right plug makes the dome lights go out, so I know it has to come in that right plug
Welcome to the forum. You are on the right track. It is one of the grey wires in the right plug for the overhead console. You are probably not getting a good connection to the tiny connectors in that plug. Not sure what kind of test light or multi meter probes you are using but try this. Open up a paper clip and back probe the connectors for the grey wires. What I mean is probe the connector from the back side or the side that the wire enters using the paper clip as a probe and connect your test light or multi meter to the paper clip to get a good connection. Remember that the dome light circuit will time out so when you have your paper clip, test light or multi meter  circuit complete open and close the door and you will see the gray wire energize and turn off when the door is closed.
Let us know if that worked for you.
Thank you for getting back to me. I took your advice and used a paper clip from the back of the plug. Made sure that I had good ground and, of course, made sure these new lights worked when plugged directly to the battery. I still find that neither gray wire has power when I open the doors. But I did find that the brown wire with the blue tracer did. I tested them all and a couple of the other wires had low voltage coming through when you open the doors. The brown wire was the only one that was exactly what I needed for dome lights. Not sure why this would be different on my truck, but it is.  It was in the third slot from the bottom right in the plug when plugged in.
Giad you got it working. I have a 2025 Trail Boss that I am going to do this mod to. I will be checking on that brown w/blue wire that you mention.
My tips are: Tap the wire with a red t-tap splice, the blue ones are probably too big.
Buy the cool white bolt lights, they match the other lights exactly.
You don't need to disassemble the black backing off the ceiling console like the OP did. Just remove the part you'll be drilling and make sure you drill directly centered on those tabs sticking out of the back of that piece.
I am getting ready to add RGBW LED modules that I have leftover from another project to our under the dash and rear seats.  I want the white to come on with the doors and the blue with the running lights, but modules and tape light all use a common positive wire and switch the negative to turn on the different colors.  A friend that knows electronics suggested I use a Low-side transistor off of my +12 trigger to control the LED as I want them to dim up/down with the dome light.  I am looking at about 8w at 12V, will that cause issues with the BCM?  Also is the BCM in my 24 Sierra AT4 closer to the gas or the brake peddle? Just not enough space to get my big head under there to look.
20250111_135404.jpg.
I found the schematic for the roof connector...
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
