I went with the MF 11229. 3" in and out as the flapper valve drops down to near 3" into and out the stock muffler and had removed the rear flapper. Wow start up, idle and throttle sound great. Cruising not so much, you can hear the DFM, and it sounds busy switching all the time, and there is drone in DFM mode while under load till more cylinders activate. Ill be getting the rear flapper put back in, I am sure it'll kill the startup rumble but the on throttle sound will be great and the dfm chop and drone should be gone.
Did you leave the downstream or upstream flapper in place?? How does it sound??
This “kit” leaves the upstream flapper. It sounds good takes time to get used to. When you hit the gas it’s pretty throaty [emoji16]cruising its quiet
Ryan B.
I ended up having mine done a couple of weeks ago. I had them delete the muffler and leave both flappers. And I left all the resonator mesh uncovered. Man, what a difference! There's no drone on the highway until around 80-85mph and only slight DFM noises every now and then. It only cost me $75 and I can't believe I almost considered dropping $1400 on the whole system after hearing mine now.
Here's some quick examples:
Update. The installer put the pipe inside the adaptive valve and the counter weight got stuck open. So now that its addressed it sounds awesome cruising. You can hear the DFM but its not intrusive. Any one with the delete or muffler swap that kept front flappers in place get rid of the resonators. Have a sound clip
Edited by Dman10
Spelling
So they stuck a smaller pipe inside the already small pipe that contains the flapper?
[emoji848] how did that happen? I don’t think the delete pipe could fit inside then stock pipe unless they modified it to jam it in [emoji2373]
Ryan B.
He did. The adaptive valve is like 3-1/8", he stuck a 3" pipe in there feeding the 11229 mf. Its now sorted and the pipe is over the adaptive valve pipe.
Stock is 3.0" muffler in out.
However stock pipe is 3.5" that drops down to 3.16" for the adaptive valve to 3" into muffler. If you delete everything 36" of 3.5" should span the gap, if you"re keeping the adaptive valve you'll need to have a muffler shop flare an end or buy a muffler delete pipe like magnaflow sells.
I have a 4" in 4" out offset piece of exhaust piping about 40" long I may just have a muffler shop slide over the 3 1/2 and then make a piece at the back of the the piping to adapt to the 3 1/2 stock piping.
Would love to hear additional sound bits of drive-bys and under load.
+1
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,585 Guests (See full list)
