Chevy Longevity
Greg
My friend at work asked me about the voltage light that just turned on in his '96 Lumina. I told him with that age vehicle, it may be his alternator and he should stop a good auto parts store down the street and have them check it out. He said he didn't know much about what was under the hood because he hasn't had any problems with the vehicle except one minor electrical component in the transmission once. He bought it new in 1995 and it now has 241K on it!
He ended up going to a different and further away auto parts place that mis-diagnosed the problem as a bad cell in his battery. The car would no longer start so he spent all evening in their parking lot trying to get at the buried battery in the Lumina. He eventually gave up due to darkness and returned the battery. He had the car towed to the Chevy dealer and they correctly diagnosed the problem as a bad alternator. He was a bit of a celebrity when he went to the dealership and everyone wanted to talk about his 241K Lumina still running strong with the original 3.1 engine, trans, water pump, etc, etc.
I have a 1991 Chevy Cavalier that has 212,200 miles on it. Engine and tranny are still original. I bought it back in 1995 with 54,000 miles. This just shows that if you take care of your car, and change your fluids often, your car/truck will last probably whatever the make or model.
My In-Laws just totalled their G20 Conversion Van. The tranny was replaced but the 350 was never touched and the van was pushing 200K miles.
I had a 95 Lumina also. d**n good car. It of course had the optional "X" motor which was monumentally more difficult to work on, but nonetheless. The alternators are a 15 minute job on 3.1's.
I still have a 96 Monte Carlo (the Lumina's sister car) with the same dreaded "X" motor that just turned 120k which is the equivalent of the 3.1 hitting 241k due in part to it's "tempermental" personality.
Truck is over 173K and runs like [better] than when we got it with 140K. no problems whatsoever, I think only repalced a EGR.
We used to have a 90 Grand Prix 3.1L with 210K, ran so good my dad regretted selling it for months
GM's Rule! Simplicity and longlivity, while staying competitive!
If he had gone to the other auto parts place, they probably would have correctly diagnosed the problem as the alternator and he'd have been on his way after a quick change. However, he wasted the whole evening trying to get at the Lumina's battery that's buried under the cross brace, and the washer solvent tank, and the fuse box, and the airbox... He had it towed to the Chevy dealer and it cost him $275 for a new alternator! The total bill was $800 which also included a new serpentine belt, idler, and headlight switch (that had been acting up also).
I feel for you with the X engine. My son was looking for a Monte and saw lots of them with the DOHC 3.4 that looked nice. I said run, don't walk, away from those cars.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
