Power window wont stop at full close
Hey folks, my passenger side window will go auto-up and then bottom out  fully closed, then slightly retract about 1/2 inch.  It isnt open, per say, but it isnt fully closed.  It reminds me of a garage door where the down setting is set too far and it reverses when it bottoms out.  Im hoping this is just a limit switch adjustment at the dealer.  Anyone else have this issue?
I'm sure you talking about using the switch at the drivers door, so try this. Roll the window up by holding the switch, not using the auto up. Keep holding the switch for about 8-10 seconds after the window closes. If it stays closed, try open and close with the auto function. If it still opens back up on its own, it may need to got to the dealer. If you have tinted windows, the dealer may try to blame that.
