Hi. I recently purchased a 2008 silverado 1500 5.3l and I'm trying to solve a very bizarre issue. So when I dont plug the truck in, it starts great no matter what the temperature is. Even down to -35 it still starts fine. The issue is when I plug in the block heater. If I plug it in overnight and try to start it, it chugs and misfires like a diesel on a cold start. It'll even sputter and die sometimes. Doesnt throw any error codes. I've never seen any vehicle have issues starting by plugging in the block heater. I had a 2009 4.8 that would think the engine was overheating if you plugged it in. It would turn the ac off and turn the electric fans on. I feel like it has something to do with a wacky temp sensor or something. Anyone experience something like this before?
The i.a.t. and c.t.s. are not telling the same story to pcm, confusion,if it is before 6 hrs,no problem,after,that is called the "soak"they should be telling the same story,parameters are set to close in pcm,I think 30° is the worry point
Yeah, I've run into that a few times but nothing that bad. My 2012 truck would fire right up, then bog and catch itself before returning to a normal idle. Having my trucks block heater on a timer helped because it still kept the coolant warm but didn't let it stay on the whole entire night.
  • 5 years later...
I have a similar issue with an 07 volvo S80 V8.
I use a timer and run power to the block heater (BH) for 2h from 3:30 to 5:30 I start the vehicle between 5:31 - 5:45, outside temperature is anywhere from 15 to 30F. On start up the engine chugs like I have an after market cam but never dies. My intent of using the BH is for better engine life and a quicker warm up time. My morning commute is only 7mi and I imagine I get heat just a little quicker with the BH. Starting without the BH I have no audible engine hesitation.
BH
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
