PICS of STANDARD bed crew cab 4x4 leveled or slightly lifted
Anyone have any pics of a leveled out or slightly lifted STANDARD bed crew cab 4x4? I know majority of people like the short bed crew cabs, but I will need the standard bed for work purposes and hauling. I'm coming from a 3/4 ton and can not use just the short bed.  I will level it at minimum but am leaning towards a 3"-4" lift.  Can't justify paying $70K for a diesel crew cab any longer with the upkeep and not needing it in an every day issue. I have a 31' bumper pull camper w/ one slide. Weighs loaded about 10k-11K. Any one pull something similar to this with this truck? Won't pull it anymore than 10 times a year with less than an hour drive. Also have a 22' pontoon boat but weighs considerably less than the camper.   I've had a diesel for about 15 years. Drove 1500 GMC's before that. Any help on either circumstance is much appreciated.  THANKS
That is a lot of weight even for a max tow 1500. A level will just make things worse while towing and not sure what legit lifts do to tow ratings. However I have seen a couple leveled and they look great.
Probably be just fine if you use weight dist hitch and maybe bags. Just stay out of traffic.
