Please read the title people 18" factory rims
Not 20"
Not aftermarket 18s (different offset)
It's frustrating when u look for info and have to comb thru a bunch of useless post to find what ur looking for
Sent from my Moto Z (2) using Tapatalk
285 75 18's on 18x9 +12 offset, the offset had me rubbing at full crank, upper control arms, aftermarket keys, shock extenders.
Stock wheels probably would have worked with stock everything with these tires.....
Oops, non stock offset, sorry.
Just plain disregard, can't find out how to delete, wrong everything.
Edited by gearheadesw
  • Haha 1
I ended up Finding a Set of 37x11.50r18 Nitto Ridge Grapplers Super cheap, once my truck is out of the Shop(Waiting on a Brand New Allison Trans, Mine Apparently had a groove cut in the bell house and had a consistant slow drip 17K miles) i will crank my torsion bars and see how the pizza cutters fit!
Any update yet
Transmission came in Monday, dealership said I should have my truck back on Thursday so I’m hoping to put them on Friday I will add pics when I do
Waiting to hear how they fit to order my set
E3A87D18-877B-4DB1-956D-5C9253CBFDDE.thumb.jpeg.edf93a6a51f4434c7c474843894a19c3.jpeg22750255-5C5A-4178-BE56-12F672C27512.thumb.jpeg.6f73f116e0a5e4e38cdbe89c2bd78cb5.jpeg
Was finally able to crank my torsion bars and get the 37x11.50s put on today, love the look, they do not rub on the fenders but do rub the frame at full lock, I’m not sure if a 1/2” spacer would help or not
You’d have to have someone turning the wheel while you checked how much it hit the frame. Being the the wheel is angled you don’t gain the full 1/2”. The other thing to consider is will the 1/2” push out cause fender rubbing by the outside of the tire?  You could fix one issue and create another
Bryant87-your truck looks fantastic on the 37’s!  First one I’ve seen with factory 18’s and a larger than stock tire.  I assumed the 11.50 would rub less than a 12.50 on factory wheels but I haven’t seen either setup up close to verify.  Either way, well done.
How does it ride and drive compared to stock?
Edited by 2011Chevy
Even with the torsion bars cranked 2”s the ride is fairly close to stock (I was expecting worse) I can feel the bigger tires a little in the steering wheel but nothing that would make me want to change my tires, rides much better than my Cummins I had with 35” MTs, I was a little nervous tho because a buddy of mine has a 2020 gas with 295/65r20s and he said his ride like a tank compared to his 2013 duramax
That’s good to hear.  Your truck (LT) and this setup is what I’m looking to do when I get my 2021.
do you have any idea how bad your buddy’s mpg is on his 6.6 gas with the 295s?
I know when it was factory he was getting about 14-15 avg, I believe he’s getting around 13-14 now.
here is a little different angle, at the front fenders I am 4” taller than stock (stock with 20s are 1/2” higher than with 18s because of the tire size)8599EF5F-BF7B-4912-95A2-678C0C37A2FD.thumb.jpeg.b4d8bd5e15a37ed478b77841b871a56a.jpeg
  • 3 weeks later...
  • 5 months later...
Just order myself some 37x12.5x18 for mine. Also adding some Fab Fours bumpers and a few other goodies to mine. Hope this helps..ill post if all goes well.
  • 1 month later...
On 2/11/2020 at 7:00 PM, jordyinaz said:
Hated the 20" Denali factory wheels.  Went with 35 x 12.50R18 Toyo M/T's.  At this point I've only got the keys turned up, but  I have the Cognito upper control arms and keys to swap, just waiting for shocks so I can do them all at once.
What Wheels are those? They look nice. Clean.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
