I bought a 2019 sierra 1500 and the air blows out of all vents no matter what mode I have it in. When it's cold out my feet seem to stay cold but my upper body is hot. I took it to the dealer and they said it is normal and they all do it.  I've heard about this issue with previous model gm trucks, but I couldnt find anything on the new generation trucks. Is anyone else having this issue or is it something specific to my truck?
My 2019 Silverado rst does this. I asked and they said they all do it as well. I find it annoying because my windshield fogs up at times unless I use defogger
Yup, Totally lame as with AC always on too!  Anyway you have to turn Fan OFF and put on Recirculate and then your good to go!
I was hoping it was only a winter issue, because I dont care as much about ac blowing out all the vents. I guess that's an issue too. What do you mean by "turn fan off" turn it on auto?
No...I had difficult time with it myself and still do..LOL  the Screen has to to say FAN OFF and then push in recirculate button ON.
Well I hate to disagree with your service advisor or whomever told you this but it's not "normal" and they all don't do it.  My '19 RST, our '19 Fire Dept. Custom service truck and a friends LT doesn't do it.  If the defrost only is selected air doesn't blow out the vents.  When the defrost mode is on and I select the vent mode, you can hear the flap inside the dash open then air starts flowing out the vents.  What gets me with these service dept.'s is when people bring a vehicle in for a problem or concern they seem to reply "they all do that" or "it's normal".  When they tell you that, tell him/her ok lets go try a handful of trucks on the lot and lets see what they do.
The AC light doesn't mean the compressor is engaged.
Just means that it is available.
Humidity control is much more effective when the AC is used.
Yes, I get that my average humidity is 13-15% so I don't need "Humidity Control" and please explain how this "Humidity Control" is utilized without the AC Compressor running?
A quick update, the dealership mechanic put in a inquiry to GM and he said there was no fix for this issue. He said he would call me when they figure out a fix, which I expect will be never. I used the vents for the first time today and there is barely any air coming out of them, it doesnt seem right to me.
Nope not right. On vent mode air should be blowing hard. Something's stuck closed or not opening.  Did you try using the air settings from the infotainment screen intead of the console? Hope it gets figured out. Try another dealer.
  • 4 years later...
Yep, new 2024 does it also, was told by service the same thing”” “they all do it” except they forgot one thing……they have a lot full of other new trucks and NO they all don’t do it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,265 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
