2019 GMC Denali 2500 front bumper options
I am looking at a 2019 Denali 2500  but the previous owner has installed a total farmer bumper on it and I do not like the looks of it whats so ever. What have you guys installed on your Denali 2500 front bumpers from aftermarket?
Did they come already coated in the color you need?
Anyone have a white frost tricoat bumper laying around if I do but this truck?
Posted in wrong section. This is the '19/'20 T1 new body 1500 section. Post in the 2019 2500 section.
You likely could post that for trade on your local facebook or offerup and have a swap setup for the weekend. Allot of hd owners want that kinda expensive bumper.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
