2017 Sierra GMC 1500 torque converter
Dwayne Walley
Is there a Break In time for a new installed torque converter?
Mine had a shudder at 60-70mph. They found fine metal in the fluid and replaced it. I think i still feel the shudder. Dealer shop says to drive a few hundred miles to break in.
DW
DW
8 Speed or 6 ?
DW
Not to veer off your question but did you get yours replaced under warranty? If so how did you talk them into it? I just got mine back yesterday from the dealer. They said they couldn't find an issue. No codes, fluid good and is blaming my shudder at 70mph on tires. I know it's not tires because it was present before I put on new tires.
Sent from my SM-N975U using Tapatalk
That’s BS on their part, take it to any Chevy or GMC dealership and go from there.
Sent from Above
DW
Take your truck to a Discount Tire or similar, ask for a Road Force Balancing and go from there, if it’s still the same then go back to the dealership and tell them to fix it cause it’s not the tires.
Sent from Above
I had this happen on my girls Camry.. when they installed a new one per service bulletin, it was truly like a new car.. drive so smooth.. maybe because we just ignored it and got used to it but. In my opinion.. it should work perfect with the new one. No “break in time”.. then again I’m no engineer, just a helicopter mechanic so what do I know.
Sent from Above
I did have it at chevy. I might have to try another. To be honest I think they may be pushing me off till my warranty ends before it's fixed. I didnt tell them I have an extended.
Take your truck to a Discount Tire or similar, ask for a Road Force Balancing and go from there, if it’s better then it was the tires, if not then go back to the dealership and tell them to fix it.
Sent from Above
Highly doubt that, they get paid for the work they do through Gmc. I once had steering issues in my 2016 Duramax, took it to closer dealership and they found nothing wrong, took it to another and they replaced the steering box. Best thing you can do is go elsewhere for a second diagnosis without bringing up another dealership.
Sent from Above
Sent from Above
Copy that.
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 878 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
