Has anyone added the 110V outlet to there interior and if so how difficult. I have a 2019 RST Z71 and it does not have it and I would like to add it. I don't know if behind the blank plate if the wiring is there or not but if anyone could add some insight I would greatly appreciate it.
Simple answer. It can't be done with factory hardware.
I took that trip and found that if it's not ordered from the factory, it can't be upgraded.
Sent from my SM-N960U1 using Tapatalk
I plan on doing this in mine as well, used it often in my 15.
Im going to get a good inverter and run a new primary wire from the battery (will be useful in the future as well) then connect to the factory blank with some diy.
You could most likely make 3 of your own for what the dealer wants.
Ps I believe this has been covered multiple times.
Sent from my ONEPLUS A6013 using Tapatalk
Used it for what. I just ordered a 2020 that has that inside plug. So I'm asking what would I use it for?
Everything from a crock pot to keep food warm traveling to parties, to chargers for tools. It even ran the combustion blower for my stoker stove in a pinch once when I lost power.
Iirc it was nowhere near 15 amps, couldn't run high draw items.
  • 3 years later...
The panel on my 2019 Silverado 1500 RST can be pried off and voila! Two plugs are attached to the back of it. They fit perfectly into an OE electric power outlet I bought to begin a power outlet project. Car companies put in these simple inexpensive harness pigtails to make it easier for their assemblers at the plant. Now the problem presented is what/where do these go to behind the dash? The easy answer would probably be to analyze the wire color codes for the vehicle and trace them back to somewhere.
Edited by Alan D Learned
Poor grammar
Yes there are wires there. I believe there are even wires that run to the rear for the bed plug as well. The inverter is mounted on the back wall of the cab behind the seat. However just hooking things up won't make it work like from the factory.
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
