https://www.youtube.com/watch?v=NkLYY1XMVbY
What bothers me in particular is the category "hitch compatibility".
Sure, the RAM barn door design looks better in that case, because there's no trailer attached. I think that with most trailers, one wouldn't be able to use the barn door, because it would hit the jack.
They criticized the Ford and GMC because the steps couldn't be used with a trailer attached. Well, that's why GM trucks have very handy corner steps in the bumper.
After all, I think that the GMC with the corner steps is the best setup when it comes to having easy access to the bed when towing a trailer.
so long
j-ten-ner
so long
j-ten-ner
I think most of the newer tailgate stuff is answering a question no one asked. I think the corner steps work well.
42 minutes ago, Cpl_Punishment said:
I read a story from one media type who was of the opinion that the Ridgeline has the best tailgate design these days.
I think it's even worse than the RAM barn doors. Considering that there's a trailer attached.
so long
j-ten-ner
so long
j-ten-ner
So what do all the Ford and Chevy owners with standard tailgates do when they have trailers hooked up?
I really really like the Ram “ barn door” style.  The tailgate doesn’t get in he way of trying to reach up in the bed.  That tailgate would not interfere with any of my boat trailers or my utility trailer.
The Ridgeline tailgate swings open as a whole. I thought that's what you were referring to.
so long
j-ten-ner
so long
j-ten-ner
But it also drops down like a traditional tailgate.
Every tailgate on the above mentioned trucks drops down in the conventional way. That's not what I'm talking about.
It's about the fancy way of the different solutions to gain easy access to the bed and the usefulness when a trailer is attached.
so long
j-ten-ner
Couple of issues with TFLs review. They failed to mention the hitch view on the GMC tailgate camera. Not sure if the others have the same function but it should’ve been mentioned either way.
The biggest thing that the TFL failed on with their review is the overall functionality of the tailgates. The Ram & Ford tailgates are one trick ponies. The GMC not only has 6 different functions, you can also add lights & a radio for additional functionality. They made a brief mention of other features that the Multi Pro has but they completely dismissed it in their categories & point rating system.
It’s almost as if they ignored it on purpose and ignoring features in a “tailgate features” review, totally negates the review itself. Dumb.
  • 4 months later...
All I can say is some of the trends are crazy! I am just glad that Dodge chose the Big Horn Sheep are a mascot about 20 years ago and not something like a Mountain Lion. Otherwise we would have trucks driving around with "****" on the tailgate! ?
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 0 Anonymous, 422 Guests (See full list)
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
