2019 Silverado 1500 Stealth Torch Grille
Installed it this weekend. Here are some pics and specs. Ask away if you have any questions About the grill or install.
  • 3 Year Warranty On Finish
  • 12 Gauge Frame
  • (2) 6 Inch and (2) 10 Inch LED Straight Single Row Slim Light Bars Included
  • Wiring Harness Included
  • High Intensity CREE LEDs, 1.3 15 amps, 6000K Color Temperature
  • Spot/Flood Combo Unbreakable Polycarbonate Lens
  • High efficiency heat dissipating Die-cast Aluminum Housing
  • Formed Mild Steel Woven Wire Mesh
  • 1 Pc Replacement
Great looking grill super clean. Great light output too. Congrats
2 hours ago, AJMBLAZER said:
How’s it wire up?  How are the lights activated?
Will give you pics soon. Got caught up at work late.
I love it... Seems a little light compared to the black on the stock grille. All around awesome though! Do you have any night pics?
