I get a lot of questions and messages about my truck and a few members asked why I don’t have a build thread, so I’ll list all my mods and pics in here for everyone’s viewing pleasure.
My goal with this truck is to keep it clean and practical but do somethings that are totally unique and custom. It’s my daily so it’s mostly used on road but we go on family camping trips when we can so it’ll have an overland style to it. I’m in construction so I’ll be adding a few things to help with tool storage as well.
Here’s how she currently sits...
Edited by Ryguy
2019 TB Custom
5.3 6 speed
Current mods:
Entire truck de-badged
Katzkin leather interior black with white stitching
Flowmaster fx catback exhaust
Go rhino running boards
Sealight led high and low beam headlight bulbs
Ridged SAE led fog lights
Atturo trail blade mt 35/12.5/18
1.25 “ wheel spacers
Black extended wheel locks
Eibach Pro truck struts and springs
Here is me and my truck when I drove it home from the dealer bone stock:
Edited by Ryguy
Update
What modifications did you have to make to get the wheel spacers to fit without rubbing?
I want 1.25" spacers on mine with the stock 20" LTZ wheels and 275/69R20 tires.  I've got TrailBoss lift with extra 1.5" leveling up front.  I've been told spacers will work but when I turn the wheels and look at how close the tires come to the fender/mudflap, I see no way they'll work without some serious modification.
Edited by lapoolboy
I removed the mud flaps trimmed a bunch off the inside of them and removed the bracket that pushes them out. Then I just started trimming the fender liner. Before I lifted the front I was rubbing on the inside of the front liner so I trimmed where the tires were hitting, the more i drive it the more I trimmed until it stoped rubbing even at full lock forward and reverse with flex. You have to be able to take a knife to the truck to make it all work but if you cut clean lines and smooth out the trimming of the mud flaps it looks factory.
Now that the front is lifted a bit and the trimming of the fender liner I could try to stuff 37 (36.5) tires in there but I’m sticking with 35x12.5 and going to 17’s.
Thanks. I didn’t re-gear. The tires probably hurt my mileage due to rotational mass. I’ve had them on since 250 miles so I don’t have anything to compare. I live in hilly country road territory so my truck averages right below 15mpg right now. I don’t think it needs a regear the 5.3 has plenty of power for a truck imo.
On 3/15/2020 at 12:30 PM, Ryguy said:
One of these days I'm gonna finally work up the nerve to pop this grille out and put my flashing in, I love the look you have on your's...
With the wheel spacers did you have to trim the wheel studs or get shorter studs? Can you provide details on how those installed? Also, what brand did you use?
Do it! If you Don’t like it you can always change up the color or even take it out. Thanks!
No need to trim because the stock wheels have openings between the stud holes on the backside of the wheels. The spacers come with studs installed so putting them on is simple. Take off the wheel, add the spacer with the nuts and a lil lock tight, put your wheel back on and enjoy the new stance. I forgot to mention I’m using black wheel locks because the chrome ones were to bing.
I run these hub centric  spacers, haven’t had any issues so far. I went 1.25 because it puts the edge of the tire right inside the fender.
https://www.4wheelparts.com/p/g2-6-on-5-5-bolt-pattern-with-1-25-wheel-spacers-black-93-83-125t/_/R-FCNB-93-83-125T?gclid=EAIaIQobChMI0O22kKSn6AIVhKDsCh15YQkPEAQYASABEgL6aPD_BwE&ecmp=s:google_1749764047_67406058414__aud-320825496947:pla-668137088306_G2 Axle and Gear_G/293-83-125T_base_US&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&ef_id=EAIaIQobChMI0O22kKSn6AIVhKDsCh15YQkPEAQYASABEgL6aPD_BwE:G:s&s_kwcid=AL!7836!3!340663058860!!!g!668137088306!&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - NTM Mobile&ecmp=s:google_1749764047_67406058414__aud-320825496947:pla-668137088306
5 hours ago, MTBR said:
Looking good! Thanks again for the help on mine.
Thanks man! How’s the new tire set up, you start trimming stuff yet?
My new wheels and tires are sitting at the shop but I can’t get them installed because everything is closed where I live. So the build is on hold right now.
No updates yet but I’ll be posting pics of the new wheels and tires as soon as my shop re-opens.
Loving it. I installed the 1.25" BORA spacers, removed all the mud/aero flaps, removed the liner brackets, and used some self tapping screws to pin back the liner. Just the slightest kiss on the liner at full lock.
Also installed the Rough Country in-line speedo converter.
Got my eye on those Eibachs now...
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
