Underhood light Mod
Hey there!
I picked up these "Partsam Pod LED Rock Lights” from Amazon- 4 qty for  $23.  They seem really well made for the price- all metal body, sealed circuit board, 100% waterproof.
I used 2 of them for footwell lights, and then I installed one as an underhood light.  I tested it before the install and it's plenty bright!  I'll post some pics tonight...
The pod is mounted to the underhood sound pad only, I used some fender washers under the nuts to keep it from pulling through.  I also installed 2 more xmas tree fasteners just to keep the material secure  (it was fine before that, but I wanted to make sure it'd be good in the long run.
I picked up power in the driver's side underhood fusebox  and mounted a switch on the firewall.  I circled the power, fuse and switch.  I also made a small plate to hide the switch wires.
It's a cheap, easy , fun little project that will really come in handy ...
Night pics!
I have the same idea except I will be using a Mercury switch to activate when hood is up
Sent from my Moto Z (2) using Tapatalk
I thought about that too- but I was bored...there was this toggle switch...lol.
I can’t wait to post night pics- it’s really well lit!
Like mkeddie said I have an old school underhood light that I just screwed into the bottom of the hood. I had a LED bulb in there but the heat from the engine was melting the solder and it failed so I just put a halogen bulb in there.
You could always put a tilt switch under the hood so that when you open the hood the light comes on automatically and use the momentary switch as a bypass so you can flip that and turn off the power if you don't want them on.
Either way that is one clean and sharp install you did.?
16 hours ago, Limelight said:
Night time pics!   I'll update the first post too...
great job and love the details but do you have a ling to the lights you used?
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,182 Guests (See full list)
