So I maybe crazy, but you know when you change your oil and when you start the engine after putting new engine oil in you get a quick lifter noise until the engine pressure comes up and oil flows throughout the engine?  Well I get that noise every morning, engine must completely drain to pain and it’s like it’s got that noise of starting dry every morning after sitting over night,
5609 miles, I changed original oil at 3500, replaced with Amsoil Signature and Amsoil filter,  i
anyone else hearing this?
Cap, is the oil approved by GM?  Did you change the viscosity?
I also get a slight tick every morning. Appears to be on driver side. Goes away when warm. Started at about 10k miles. I use shell rotella gas truck. I have the 5.3
I get it too, but I will say when I changed to using Mobile one from the GM oil the noise greatly reduced.
It should should like angels singing and the exhaust should be perfumed, since Amsoil was used.  ?
Are you possibly talking about the two-stage oil pump sound?
  • Haha 1
Currently running 0w20.. could be the pump noise, not sure,  I’ll take a video and post tomorrow morning.. is the oil approved by GM? It has all and more certifications to comply with Gm specs,
Edited by jbshoo
No, Amsoil isn’t Dexos certified. While it exceeds the actual standards, they didn’t pay GM the “Dexos ransom” as some would call it. But hey...Amsoil products are “warranty secure“. Which means GM will blame the Amsoil, Amsoil will blame GM for a manufacturing defect, and nothing will get fixed in the meantime. ?
Only kidding, of course. I’ve never specifically heard of anyone having warranty problems over using Amsoil or anything else within spec.
DI engines are noisy and generally sound like crap. But mine never makes any odd noises upon startup that it doesn’t make any other time. Just using the AC Delco oil and filter.
  • 1 year later...
Bob2C, your video is spot on with my 2020 Silverado 1500, 6.2 ...same exact noise ...did you ever find out the cause ? I have an appointment with the dealership and if I find out first ..I will re post here !
Thanks
Michael
On 3/26/2020 at 6:23 PM, Bob2C said:
This is the noise on mine
Curious , did you ever find the problem ...my 6.2 Silverado - same exact noise.. have an appointment with dealership to see what is going on... -thanks
    Mistycool
    Mistycool
  • Who's Online   2 Members, 0 Anonymous, 1,914 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
