Hey all.   I live on a dirt road.   Despite having a paved driveway of about 100ft, it is no where near long enough for the tires to rid themselves of the dirt.
Anyone have ideas on garage flooring? Right now I vacuum the garage floor with a shop vac about twice per year (spring and fall)  and I have to blow out the filter multiple times because the sand/dirt clogs it up rather quickly.
Sweeping isn't really an option as it gets super dirty no matter how careful i try to be = shelves and all items on them covered in dust.
I do see that they make these huge mats you can lay down that have a lip to contain water.   These look nice but I'm not really interested in spending hundreds on that.
My next idea is maybe some outdoor type carpeting? Maybe cut up two pieces to follow the path of the tires.   Cleanup would be fairly easy,  I think.   Could power wash or simply shake it off outside. Not sure what would happen after driving in the rain and parking on it.
Anyone have any thoughts or experience with this?  Also would need to do on the wife's side as well.
Edited by SkiDooNick700
  • 5 months later...
I have the epoxy flooring.  Several layers of it.  The Rust-o-leum kit stinks BTW.  It needed to be re-done every year it seemed and would pull up if the tires were warm/damp then sat overnight.  I ended up going with the premade Behr stuff at Home Depot and haven't touched it in 10 years.  It could be re-done just to freshen it up, but it's not due to damage.  it's held up fine.
Second, I have a carpet runner down for the path of the tires.  Get one of those sharks for the garage and you're set.  Unless you're tracking in chunks when it's wet.
Real only picture I have of it;
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
