Your good/bad experience with vehicle WiFi?
Hello,
I'm thinking of adding my vehicle to my ATT cellphone account. My specific application in question would be for camping in remote locations where cellphone signal is spotty at best. Is the shark fin antennae much better than a handheld iphone X? What's the best range you've got outside the vehicle barring obstructions?
Trying to justify the expense vs the inconvenience of hiking up a hill and stuffing a coat hanger up my butt just to get a solid enough signal to do small data transfers.
Thanks for the help.
Isn't the point of going camping to be off the grid?
The signal is stronger than a cellphone, but if you're somewhere truly mountainous/rural the connection speed will likely be quite slow.
I bought the prepaid package for a year at 200 bucks. Speeds are dismal. I live in an urban area and generally get 5 to 6MB down and about 2MB up. It can get slower at times. It’s prepaid. I did not add on since I don’t have att for service. I have cricket prepaid ( owned by att) and my cell phone service is a lot faster at 80MB down and 20MB up mostly. I did notice that the car gets a better signal than my phone. So yes in rural areas you will have service. I did hotspot my phone to truck before purchase the data plan but it’s a pain everyone I get in the truck to establish a connection. Have to manually go into my iPhone and connect. I mostly use it for iHeartRadio radio and the kids use it for watching movies when we go on trips. Hope this helps.
I was at a state park yesterday with very low signal. I was trying to order subway to pickup on the way home. My phone would keep cutting out. Fired up the truck and ran the trucks wifi on the phone and completed the order. I like it
Ryan B.
Thanks for the reply. I do get it that it’s not going to be fast. I think I read somewhere that the truck is capable of 4G. In the areas where I will be, the iPhone won’t even get 3G unless I hike to a hilltop. I’m thinking this might help me out. Please keep the comments coming.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
