What can I do to get upper control arms off bump stops? I've replaced most suspension parts in the front end.  When I adjusted torson bolt back out the front end felt like it was on pogo sticks, so I put it back in rides ok till I hit a bump then BAM... And help is appreciated....thanks
Maybe post an image about what bump stops you are talking about?
I know the LCA's have what a lot of people think are bump stops, but they are actually part of the suspension and are supposed to be slightly compressed against the LCA (at least at stock height).
Assuming that you lifted the truck using torsion keys. you will need to un-lift the truck or replace the upper control arms that are made for the lift you want.
wow, you turned the keys so much the suspension is sitting at maximum extension...
I would recommend installing a proper 4-6" lift kit that moves everything by that 4" or so, so at rest the suspension is roughly in the middle of it's range of motion.
Yes I bought the truck with the keys turned up like this, when I tried to correct this by turning the torson key bolts out again. After doing this the truck rode like it was on pogo sticks in rhe front jumping everywhere....is it not possible to put back to stock?
Truck currently has air bag system in the rear, that id like to leave installed. So wondering what I need to raise the front? New keys? Different UCA'S? longer shocks? All of the above?
The pic you have in 3 & 4 show the keys are literally maxed out, so the suspension is at full extension when resting.  It's gonna ride like crap if it's anywhere near that configuration.
This is what it should look like (assuming stock components) at stock height:
The jounce bumper (the black rubber blob in the center bottom of the pic) is supposed to be slightly touching the LCA to be at stock height.
If you truck is pogo'ing when it's like this, then your shocks are shot.
If you want the truck lifted to it's current height, then install a proper lift kit.  Measure how high a certain point is, say the bottom of the front bumper now, then turn down the keys so the jounce is just slightly compressed by the UCA, then measure  again.  The difference (assuming that's the amount of lift you want) is the size of lift you want to get.
If you just go for turning up the keys and the UCA gets close it's bump stop like it is in your pics, it WILL ride like crap, and possibly damage the UCA from constantly hitting it.
Edited by davester
Wow, thanks so much for the picture and all the insight!  Really helping me wrap my head around it all.....my shocks have about 5k on them, believe I put on Rancho rs 5000, maybe just not good enough shocks?
Edited by Rpeebles587
First, turn your keys way down so the UCA isn't hitting that stop, then see how it rides.  And if you go for putting on a proper lift kit, it likely/should come with or specify new shocks to go with it (they likely need to be longer than stock shocks).
Thanks davester!!  Got the torsion turned enough and got the uca's off the bump...wow what a difference.. it's been like that since I owned the truck, lol ....riding like a dream now, bout to roll over to 190,000 on the 2000 LT 2500
  • 2 years later...
i just installed timbren bump stops and maxx cam2 keys. my adjustment bolt is turned completely out. my bump is about 1/4" off the lca. is that normal?
The rubber jounce (that's what it is, not a bump stop) is part of the suspension, and comes from GM with it slightly pressing against the LCA.
You have aftermarket keys.  You'd have to follow SuspensionMaxx's install instructions here at this point which is clearance of the upper control arm to the upper arm stop.  That gap must be between 1/4" and 3/8".
The factory keys at stock height, the jounce bumper will likely be resting on the LCA.
See the last page of the instructions - SMX-MC2HD.pdf (suspensionmaxx.com)
Edited by newdude
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
