Anybody here running this lift? What’s the quality of the struts? I’m debating either a 6” BDS with Fox, or the McGaughy SS.
End goal is running a 22x10, -19ish, with a 35x12.50. Really like the Open Country MT, a little concerned about how big they are (truly are 35”, not 34.8)
I like the idea of running the 7” setting on McGaughy and could go up more if needed. But I’m a bit Fox fan.
Appreciate any insight
I have the mcgaughys 7-10 set at 9inches and, I have always been a fox fan boy as well, but these mcgaughys shocks ride surprisingly smooth. I am very happy with the lift and ride quality, although once cognito releases there 7-10inch fox coilovers I will likely be upgrading.
a6f9a75b4d7182d100f725e286313d09.jpg3edaad2b27de280d8698d4a12381a99f.png82f5364aebdcd5108f17e0d3559a2f94.jpg
Dang son.... looks really good, what size tire wheel setup you running?
How did you get rid of the mudflaps on the front fender liner?
Just trim them off flush, have to keep the top part that clips on to the fender.
Any chance you can get a close up of the mud flaps.
How is the ride quality compared to factory ?
Does your truck squat a bit or did it settle in the front?
What did you do to correct the speedometer. I used the rough country corrector but it causes my remote start to not work
I didn’t use anything as my speed is only 2 mph
It’s has a just a ever slight squat, very minimal
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
